liberty hand brake for l?
Posted: Sun Aug 23, 2009 12:27 pm
by Learner
hey, i'm installing a crossbred kit for my l. can i use a lib hand brake lever instead of a magna one? also who knows how many splines on the shaft of an L mpfi (auto) iare?
cheers for the help
Posted: Sun Aug 23, 2009 12:29 pm
by AndrewT
handbrake - Not sure of the exact differences but I assume definitely not. Otherwise Crossbred would just advise this as it's obviously easier to source one.
shaft - what shaft are you talking about exactly? and which splines on that shaft?
Posted: Sun Aug 23, 2009 1:41 pm
by guyph_01
i think he is talking of the drive shafts (cv joints)
From what i have learnt, all the L series have 30 splines on the outer joint and the MPFI or turbo have 25 but the N/A or carby ones have 23 on the inner joint that attaches on the gearbox.
Posted: Sun Aug 23, 2009 3:38 pm
by rtcb65
Learner wrote:hey, i'm installing a crossbred kit for my l. can i use a lib hand brake lever instead of a magna one? also who knows how many splines on the shaft of an L mpfi (auto) iare?
cheers for the help
The easiest way is to contact jeff at crossbred performance and he will let you know what you need to know.
Posted: Sun Aug 23, 2009 4:34 pm
by Learner
cheers pretty much got all the info now.
thanks guyph_01 that's what i meant
Posted: Sun Sep 20, 2009 11:07 pm
by mattl200
with the handbreak lever if your handy with the welder you can cut the mounts off both handbreaks and weld the lseries mounts to the lib handbreak
