liberty hand brake for l?
hey, i'm installing a crossbred kit for my l. can i use a lib hand brake lever instead of a magna one? also who knows how many splines on the shaft of an L mpfi (auto) iare?
cheers for the help
cheers for the help
1989 L touring wagon auto (project)
1969 beetle street car (project)
= me:)
= me:)
handbrake - Not sure of the exact differences but I assume definitely not. Otherwise Crossbred would just advise this as it's obviously easier to source one.
shaft - what shaft are you talking about exactly? and which splines on that shaft?
i think he is talking of the drive shafts (cv joints)
From what i have learnt, all the L series have 30 splines on the outer joint and the MPFI or turbo have 25 but the N/A or carby ones have 23 on the inner joint that attaches on the gearbox.
The easiest way is to contact jeff at crossbred performance and he will let you know what you need to know.Learner wrote:hey, i'm installing a crossbred kit for my l. can i use a lib hand brake lever instead of a magna one? also who knows how many splines on the shaft of an L mpfi (auto) iare?
cheers for the help
rtcb65
Redneck Rick.
Redneck Rick.
with the handbreak lever if your handy with the welder you can cut the mounts off both handbreaks and weld the lseries mounts to the lib handbreak
