ej converson questions
masterguitarshreader
Post by masterguitarshreader » Wed Jun 10, 2009 4:37 pm
This might be a stupid question when fitting a ej motor to the exsisting L series gearbox using an adaptor plate does it matter what transmission the donor car had manual or auto front or all wheel drive? or will all of the above work thanks:)
no more 91 l series, no more liberty sedan , 92 l series this time i will do all the mods i wated to do with my last l series, lift , wheels ,kings, roof basket, snrokel
Post by AndrewT » Wed Jun 10, 2009 5:35 pm
Nah doesn't matter. There are supposedly some small differences with the way the ECU works on auto EJ's but we havn't seen this cause an issue when running them on L series 5speeds. Mechanically there is no problem because you end up using all the L series hardware (clutch, pressure plate, flywheel) anyway.
