i fitted the dual carbs that i bought from xaymaca today... and they are sooo awesome
the low down torque is so much better than the original it now carries third up hills that i would normally need to down shift on
the only problem i encountered was the air filters.... they are very tall and didn't fit under the bonnet
. i'm guessing they fit under xaymacas bonnet because he had a lift kit installed.. correct? so i knocked up a temporary filter box using the old air filter which will do til i can find an origional air box.
overall an easy mod and its definately worth doin... if you can find a set
