EJ Dual Range AWD 1.19:1 Lo range upgrade to 1.59 {56k warning}
Everything Engine, Gearbox, Diffs & Driveshafts for the EJ series models - NA & Boosted
Post by AlpineRaven » Mon Jan 14, 2013 11:02 am
Faraim9117 wrote:I'm looking for the cable to shift the transmission in to lo and hi. The one I bought had the cable cut... I would also need the mounting bracket on the transmission and the interior lever. Any ideas where I could find these items? I'm not having any luck online.
Thanks,
Gilles
What came in my mind first thing was L series shifter - it is different as I was searching one for Gen 2 Liberty and I ended up getting Gen 1 Liberty's shifter with Gen 2 centre console and lever plastic part. I did that on Gen 2 sedan conversion from single range to dual range AWD a few years ago.
If worst to worst that you dont have one there - let me know and Ill grab one from the wreckers and send it to you.
Faraim9117
Post by Faraim9117 » Mon Jan 14, 2013 12:16 pm
I bought a shifter from an 89 loyale, and after working on it all weekend, I couldn't seem to get it to work correctly. It seems that no matter how I set it up, the two shifter interfere with one another. Any tricks? First I tried using the EA shifter but couldn't make it fit without cutting the floor. So then I decided to cut it up and only used the 4wd lever, and modified the orignal 2000 outback shifter by shortening the two links that go to the transission and extending the rear accomodate the the 4wd shifter, but that doesn't seem to work. Is using the whole ea shifter the way to go and just cutting out the floor to make it fit the better option? Thanks for offering to get a shifter from the junkyard, but hearing you say you were able to make it work is encouraging me to keep trying!
On to another question, and this maybe ridiculous. Is it possible to take out the awd rear section of the EJ transmission and use the selectable 4wd from an EA? I found a donor box to get the rear 4wd gears and lower transmission shaft that has the pinion gear on it (I don't know what that shaft is called!) but the pinion gear is 3.9 and I have a 4.11. Is the ring gear the only difference between the 3.9 and 4.11 or the pinion gear is different too?
Thanks!
Post by AlpineRaven » Mon Jan 14, 2013 12:30 pm
Faraim9117 wrote:I bought a shifter from an 89 loyale, and after working on it all weekend, I couldn't seem to get it to work correctly. It seems that no matter how I set it up, the two shifter interfere with one another. Any tricks? First I tried using the EA shifter but couldn't make it fit without cutting the floor. So then I decided to cut it up and only used the 4wd lever, and modified the orignal 2000 outback shifter by shortening the two links that go to the transission and extending the rear accomodate the the 4wd shifter, but that doesn't seem to work. Is using the whole ea shifter the way to go and just cutting out the floor to make it fit the better option? Thanks for offering to get a shifter from the junkyard, but hearing you say you were able to make it work is encouraging me to keep trying!
Thanks!
I know that EJ shifter is through the rubber grommet where the gear shifter is on the right side. Its mounted by 3 bolts next to the handbrake lever. AWD shifter only uses two position whereabouts L series uses 3. I did try using L Series shifter and didnt work - and didnt bother mucking around as I found another one from AWD and was 2 hours drive that time.
EA's shaft is different to EJ shaft and wont work. The pinion gear will have different angles for 3.9/4.1 you will have to get matching ratios otherwise itll mismatch. You can find 3.7/3.9/4.11/4.44 pinion & crown shaft to install from other subarus
Post by El_Freddo » Mon Jan 14, 2013 12:53 pm
AlpineRaven wrote:EA's shaft is different to EJ shaft and wont work. The pinion gear will have different angles for 3.9/4.1 you will have to get matching ratios otherwise itll mismatch. You can find 3.7/3.9/4.11/4.44 pinion & crown shaft to install from other subarus
And the pinion shaft is different between the EJ and EA gearboxes - you'll need to take the pinion shaft that matches the rear casing. In the EA's case, if you want the PT 4wd selectable rear section from the EA casing you need to take the rest of the gearbox with it as the lower gearsets are pressed onto the pinion shaft from what I've seen and read.
If it was a FT4wd EA gearbox you can swap the pinion shafts and centre diffs - but again they come as a matching set (EA pinion with EA centre diff etc). If you're swapping EJ stuff it's all plug and play.
The EA diff ratio came from the factory as 3.7 and 3.9 only. The EJs came in 3.7 upto the 4.44 ratio...
I wouldn't bother swapping to PT4wd just to make some linkages work - you'll have to come up with new gearbox mounts and a new tail shaft too.
AP - I'm chasing the dual range AWD gear selector rubber boot and metal surround, the high/low lever and the matching console pieces from a Gen2 in the dark grey/black colour for a US member. I've done the rounds at Centre Road and Kilsyth but nothing's turned up at the moment :(
Post by AlpineRaven » Mon Jan 14, 2013 1:00 pm
El_Freddo wrote:And the pinion shaft is different between the EJ and EA gearboxes - you'll need to take the pinion shaft that matches the rear casing. In the EA's case, if you want the PT 4wd selectable rear section from the EA casing you need to take the rest of the gearbox with it as the lower gearsets are pressed onto the pinion shaft from what I've seen and read.
Theres Gen 3 Liberty (2000) with Dual Range in Ringwood Jollys pick a part...
Its pretty quiet at the moment for dual range liberty at the wreckers that I go to. - Havent checked Pick a Part yet.
Faraim9117
Post by Faraim9117 » Wed Jan 16, 2013 2:16 pm
It looked like the lower shaft would fit, but I'm not willing to change my differential from 4.11 to 3.9 even if it would work (I didn't measure anything just eyeballing it). It's amazing how similar the ea and ej transmission look on the inside. Is the EJ transmission stronger than the EA? I know the input shaft on the EA is smalled but having that solid lower shaft makes me think the EA would be stronger. I figured this would be the place to ask if this 4wd conversion was possible and sure enough you guys knew. I'm glad I didn't waste my time trying it.
After making further modification to the Loyale 4wd shifter, I think I might be on the right track. I'm just waiting on some rod ends to make the final adjustment. But what a pain, especially since my welding skills aren't up to par.
Gilles
Post by AlpineRaven » Wed Jan 16, 2013 6:44 pm
Faraim9117 wrote:It looked like the lower shaft would fit, but I'm not willing to change my differential from 4.11 to 3.9 even if it would work (I didn't measure anything just eyeballing it). It's amazing how similar the ea and ej transmission look on the inside. Is the EJ transmission stronger than the EA? I know the input shaft on the EA is smalled but having that solid lower shaft makes me think the EA would be stronger. I figured this would be the place to ask if this 4wd conversion was possible and sure enough you guys knew. I'm glad I didn't waste my time trying it.
Gilles
Is EJ stronger than EA? - I wouldn't think so, I would say it would be about the same. Just that is the difference is the part time 4WD section. Just different design but as far I know that Subaru uses similar design since 1976 or earlier.
niterida
Post by niterida » Wed Jul 10, 2013 6:45 am
discopotato03 wrote:Hokay
Close..Teeth no .... Wide.. Teeth no .
1. 3.545 39/11 ...... Same .
2. 1.947 37/19 ...... 2.111 38/18
3. 1.366 41/30 ...... 1.448 42/29
4. 0.972 35/36 ...... 1.088 37/34
5. 0.780 32/41 ...... 0.871 34/39
Can anyone tell me if the above ratios are for the 3.7 Liberty box.
If not does anyone know the internal gear ratios for a 3.7 Gen 2 Liberty box ?
jayrod
Post by jayrod » Wed Jul 10, 2013 5:09 pm
I want to do this to my Gen 1 wagon, but i have been reading up saying you may be able to get a 98 Outback dual range for a more direct swap? Its not the same 1.59 i believe its 1.4 but better than 1.19.
Is this correct or am i just reading "Guesses"
nepbug
Post by nepbug » Fri Aug 09, 2013 3:26 am
Hey everybody, I'm in the process of getting the transmissions to do this swap, but while thinking of things I came up with a possibility, let me know if you think it's feasible.
First off, I will likely end up with a 1.19:1 reduction box as my starting point.
Now, I was thinking about this ratio and thought that it would be a great streetable tranny around my area. When I get to the steep mountain climbs in Colorado I could just switch it to low and have that extra oomph without having as big of a drop by downshifting. Then I thought, well, what if you were in that gear all the time as hi-range?
So, is it possible to swap the 1.19:1 Lo-range gear to become your high and then put in the 1.59:1 lo-range as your low?
I've got to run some gear calculations and determine what tires size I want to run so I don't know if I'd even want to do it, but I'd like to know if the possibility is there.
nepbug
Post by nepbug » Fri Aug 09, 2013 3:29 am
nepbug wrote:Hey everybody, I'm in the process of getting the transmissions to do this swap, but while thinking of things I came up with a possibility, let me know if you think it's feasible.
Of course this means your low would be a 33% reduction instead of the possible 59%, but if running oversized tires it might be a good possibility.
Overall switching the 4.11 to a 4.44 would probably be another option that could do similar things and retain better reduction ratios.
Post by El_Freddo » Sat Aug 10, 2013 8:08 pm
nepbug wrote:is it possible to swap the 1.19:1 Lo-range gear to become your high and then put in the 1.59:1 lo-range as your low?
Simple answer is no. The 1.19:1 low range is in the same place the 1.59:1 low range goes - so it's one or the other!
Swapping diff ratios is the better way to go about it, especially if you're running big tyres. And if you have an EJ gearbox it's pretty easy to do compared to a cut and shut on the pinion shaft in the EA gearboxes.
nepbug
Post by nepbug » Sat Aug 10, 2013 10:36 pm
El_Freddo wrote:Simple answer is no. The 1.19:1 low range is in the same place the 1.59:1 low range goes - so it's one or the other!
Thanks, yeah I don't have one to crack open and see for myself yet.
So it sounds like you have to swap the entire dual range portion over, you can't just swap one gear.
Sent from my DROID RAZR using Tapatalk 2
nepbug
Post by nepbug » Sat Sep 28, 2013 6:27 am
Ok guys, I'm dissassembling the EA82 gearbox right now and have run into a question.
How do you remove the cotter in front of the input shaft bearing?
tambox
Post by tambox » Sat Sep 28, 2013 12:49 pm
Its a two piece unit. Just spread it at either break in the units or gently tap one side outwards at the break.
It just sits there, but is held in place by the cover you have removed.
L serious, still.
nepbug
Post by nepbug » Sat Sep 28, 2013 3:09 pm
Ok, that's what I thought, but when it wouldn't budge when I tried to spread it I thought I must have missed something.
I'll try again in the morning, with s little more persuasion if needed now that I know that is the correct course.
Thanks.
Sent from my DROID RAZR using Tapatalk 4
Edit:
Yep, I went back and got it out of there with a little gentle persuasion from a hammer and punch.
Donkeytits1
Post by Donkeytits1 » Sun Mar 02, 2014 11:37 pm
Just did this modification to a
Gen 1 Liberty GX Wagon
mfg March 1993
3.90 final drive
I can confirm that the only modification necessary was milling of the selector fork; the spline length was OK and the front housing and bearing were also the same; All rotating parts were a direct swap.
There is not much clearance between the diff and the new synchro sleave, about 2mm!! But thats enough
TIP:
Got a 1/4 ball end tool to mill the detent pits, which is quite simple to do by using one of the selector shafts as a mount.
- Hold the shaft straight up in the mill (a rotary table and chuck work well for this)
- Mount the old selector on the shaft and tap in the dowel a little
- Line up the tool with the dentents and measure depth
- Take the old selector off and replace with the new selector
- Mill the detent pits to the correct depth
Transmission works brilliantly. MUCH better than the normal 1.19 ratio!!!
Here's my shifter fork. The detents milled with the method above work flawlessly
Shift fork 2.jpg (66.14 KiB) Viewed 4698 times
Shift fork 1.jpg (61.11 KiB) Viewed 4703 times
Return to “EJ Drivetrain”
