extractors for ea81
Posted: Fri Feb 03, 2006 3:11 pm
by SubiDave
Hi, are extractors available for the ea81 motor
Posted: Fri Feb 03, 2006 3:18 pm
by Suba
the exhaust that the subis come out with really are an extractor if you compare it to any other car with a standard exhaust , in that they nearlly all have an exhaust manifold whereas the Subis dont, you can have a tune lengthed header made but you will loose the boxer note allthough you will get a bit better hp , very minimal though.
Mike.
Posted: Fri Feb 03, 2006 5:18 pm
by MUDRAT
Yeah, spot on Mike. You're best of keeping the standard headers. A 2.25" exhaust system will make all the difference though.
Posted: Mon Feb 06, 2006 11:41 am
by SubiDave
hey guys, I didn't realise, my car I just bought has an ea82 engine, I screwed up.
Posted: Mon Feb 06, 2006 12:06 pm
by BaronVonChickenPants
Thats ok, the answer remains the same, the EA81 and EA82 exhaust are basically identical except for catalytic converters.
Jordan.
Posted: Mon Feb 06, 2006 9:29 pm
While on the topic, and EA82 Y pipe used on EA81 as a performance mod, does the EA82 Y pipe actually bolt up to EA81 exhaust system as a direct replacement or does it require fabrication to fit and work ?
(sure this question has been asked and answered before )i
Posted: Tue Feb 07, 2006 12:32 am
by tim_81coupe
Yes the EA82 Y pipe bolts up to an EA81. No, it won't give any more performance, it will actually rob it if anything.
My wagon currently runs an EA82 with an EA81 exhaust. A previous setup on the car was actually an EA81 with an EA82 exhaust, someone had told me the EA82 headers were the go. I ended up swapping back to the EA81 headers as it was a noticeable difference.
I am talking about cat-less EA81 headers, I do realise the later EA81 headers had a cat as well, these aren't the ones I'm referring to.
Yes they bolt up. No, don't do it.
Posted: Tue Feb 07, 2006 8:40 pm
ah-ha, almost expected as much. Might lack torque down low but may flow better at revving its tits off - not looking for that.
