what would be required to fit ej running gear under a MY wagon, i am mainly worried about the gearbox fiting.
i know custom shafts/tail shaft but is there anything else?
ej awd in MY
That seems like a strange way to go. Choose your gearbox first then change your diff to suit it, much much easier - diffs are easiler to source or change ratio.lovey80 wrote:I have a relevent question also that will be required........... Is there an ej AWD box that is compatible with a 3.7 rear diff?
Chris
Your gonna run into trouble fitting it in the tunnel without lift. They are larger then the PT L series boxes back there.
2" lift would fix that problem, or you can do what I done.
