My car- 84 EJ20t wagon
I just recently upgraded the surge tank to engine pump to a bosh 044, after hearing a noisy whining sound coming from the pump. As the fuel went down in the tank it would get louder.
But after installation I noticed that only half the noise went away, and the other noise was coming from the pre surge tank pump. Which I didn't replace
So I figure I should definately replace that one as well, especially as I don't want to starve the suction end of the 044.
It is a much smaller pump, around half the size.
What fuel pump would people recommend?
Should the pre surge tank pump be around the same size as the post surge tank pump?
Also there is no regulator and I'm using standard 91 lib injectors (which I hope to upgrade soon), would this be likely to cause a problem?
