Question for he who bought Cruzingbrumby's EA82T engine .
Posted: Thu Jul 03, 2008 6:31 pm
I remember looking at this engine ages ago and noted it was an import one and had a different cold start air bypass valve ie not the weirdo thermostat housing type . I seem to remember it having the type used on the spider inlet manifold and 101 Nissans from that era .
I'm thoroughly fed up with the thermo housing type and want to use the other type only I can't figgure out where it went - towards the back of the inlet manifolds water log - I think . Fingers crossed if I'm right all MPFI engines can have the better (more easily replaced) valve if need be .
Why would I want to do this ?
Firstly thermostat would be a doddle to change (which I do summer and winter) .
Secondly , I HATE engines that idle faster than they need to when warming up because it makes life difficult for the gearboxes syncromesh .
The methods used to make dinosaur engines of the middle 80's era idle when cold continue to feed air into the engine even when the throttle is open meaning a lazy return to an elevated idle speed between gear changes - until the #@^* valve closes up fully .
Short of paying stupid money for a new std one I prefer the alternative type and they are available in different sizes .
Cheers A .
Cheers A .
