engine from a auto on2 a manual box
stevonz24
Post by stevonz24 » Thu Jun 26, 2008 11:40 am
hay guys
was wondering if the engine from my auto 85 leone will go syraight into my 89 manual leone?
i tried bolting it up, but wuldnt close up. im really hoping its just that i havent got the clutch centered up properly.:rolleyes:
ive got a few days b4 i can afford to hire engine hoist again so if ne1 culd shed sum light b4 then wuld b sweeet as thanxx:-D
Post by Alex » Thu Jun 26, 2008 12:20 pm
yes it should bolt up.
Suby Roo
Post by Suby Roo » Thu Jun 26, 2008 12:21 pm
You have taken the torque convertor and replaced it with the flywheel???
If you have it should fit straight in!
stevonz24
Post by stevonz24 » Thu Jun 26, 2008 3:38 pm
yeap yeap swappd the converter for the flywheel and clutch. thanks guys ill straighten everything up again and have another crack 2mora n let yiz know how it goes haha wish me luck
vincentvega
Post by vincentvega » Thu Jun 26, 2008 3:58 pm
make sure there arent any extra dowels between the box and engine. sometimes the dowel will end up in the incorrect end and you can have 2 dowels hitting agsinst eachother preventing it from going together
Matatak
Post by Matatak » Thu Jun 26, 2008 6:44 pm
try turning the crank to
sometimes the Clutch plate will get stuck in wrong spot for the Splines to line up, and turning something can fix it.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by El_Freddo » Thu Jun 26, 2008 9:51 pm
If you haven't left the clutch pressure plate bolts loose try that out - this will allow the clutch disc to move arouns, allowing you to line up the gearbox input shaft into the bearing on the flywheel. Once you've got the gearbox on and bolted up, tighten the clutch pressure plate bolts through the starter motor hole - will need starter motor removed for this ;)
