ea 71 twin carbs on ea 81
arc1
Post by arc1 » Thu Jun 05, 2008 7:51 pm
Hi, I am pretty new to subarus. I have recently been offered twin carbs from an ea71 to put on my 81. As far as I can tell, these are a direct bolt on. However, I have also been oferred a pair of heads that to me are from an unknown model. They apparently have different cams (lift and duration) and the heads have been worked. The only clue to their origin (the heads) is that the exhaust and intake cams are on opposite sides to the ea81. At least this is what I am told.
Does anyone know if this rings true or possibly know what heads these may be?
I would appreciate any help or suggestions.
Thanks.
littlewhiteute
Post by littlewhiteute » Thu Jun 05, 2008 8:12 pm
arc1 wrote:Hi, I am pretty new to subarus. I have recently been offered twin carbs from an ea71 to put on my 81. As far as I can tell, these are a direct bolt on. However, I have also been oferred a pair of heads that to me are from an unknown model. They apparently have different cams (lift and duration) and the heads have been worked. The only clue to their origin (the heads) is that the exhaust and intake cams are on opposite sides to the ea81. At least this is what I am told.
Thanks.
Manifold won't fit, EA71 is narrower port to port (from one head to the other) than EA81.
Normally aspirated heads have in,ex,ex,in.
EA81T and dual port heads have ex,in,in,ex.
Gary ;)
Post by El_Freddo » Fri Jun 06, 2008 5:01 pm
littlewhiteute wrote: EA81T and dual port heads have ex,in,in,ex.
I'd be grabbing those heads if you can, the cam can be ground to what ever you want, but the heads are the elusive part to get. They are a "gold" piece to have if your doing up an EA81.
arc1
Post by arc1 » Fri Jun 06, 2008 5:44 pm
Thanks guys for your prompt replies. This is a new learning curve for me, my previous experience lies with other fours. I have to say though, I love my sooby.
Any other advice is welcome. Thanks.
littlewhiteute
Post by littlewhiteute » Fri Jun 06, 2008 6:18 pm
The cam has to match the valve layout, can't use normal cam with the heads you have been offered.
Gary ;)
arc1
Post by arc1 » Fri Jun 06, 2008 10:07 pm
The cams are provided with the heads. Do I bolt these on with the standard block and pistons? My research tells me that these are the rally heads and I assume that higher compression pistons may have been used with these. Any comments?? Thanks.
littlewhiteute
Post by littlewhiteute » Sat Jun 07, 2008 12:56 am
arc1 wrote:The cams are provided with the heads. Do I bolt these on with the standard block and pistons? My research tells me that these are the rally heads and I assume that higher compression pistons may have been used with these. Any comments?? Thanks.
Cams? Are we talking EA82 SOHC, not EA81 OHV?
Gary ;)
arc1
Post by arc1 » Sat Jun 07, 2008 1:55 pm
I'll find out from the seller next week and get back. Thanks.
littlewhiteute
Post by littlewhiteute » Sun Jun 15, 2008 5:20 pm
Arc1, have you found any more info?
I have a plan of making a twin carb manifold for an EA81 from two stock manifolds, a bit of cutting and welding etc. ;)
Gary ;)
