4x4 MY coupe project well under way... all standards fitted (4sp dual range box, 4wd rear, air adjust rear shocks, 2" lift etc.)
fitted L series control arms with modded MY radius rods (16mm thread bar + 50mm long coupling nut... cut end off original rod, machine, tap/thread, fit coupling nut, insert thread bar, cut to length, use 4 nuts + big washers + sml piece of pipe to protect rubber bushes from rubbing on tread bar and to stop "overtightening" on bushes) quick adjustment and done...
now for the longer lighter CV shafts... reco'd MY outers, New L series inners and shafts (shafts picked buy driveshaft specialist, pretty sure they are L ones)... big length difference...(pic of both at compressed length)
then compare MY originals sitting at centre to Custom ones at compressed and then full length..
I shall install them tomorrow and post more piccies...
BIG BIG THANKS TO ALL YOU MAD SCIENTISTS FOR ALL THE IDEAS I HAVE READ ON HERE, LOVE GETTIN MY HANDS DIRTY AND PUTTIN IDEAS TO USE...
and i have been told by an engineer that radius rods should hold up unless i take on roadside gutters at speeds lol...
