Brumby Tow Bar Options?
Hamish71
Post by Hamish71 » Fri May 16, 2008 8:47 am
I have both a light motorbike trailer, and a heavier camping trailer that Id like to be able to tow. What are the options for a tow bar for the brumby? and where do you get them from?
Post by El_Freddo » Fri May 16, 2008 4:01 pm
Do you have the standard tow bar that was fitted to the brumby? I'm not sure if this was an option or not. If yours doesn't have a tow bar, i'd grab one from the wreckers and bolt that in.
Wilbur
Post by Wilbur » Fri May 16, 2008 4:23 pm
Or if you go new hayman reece do one -
SUBARU1982-1994755 [url=http://javascript<b></b>:var%20win%20=%20window.open(]Brumby Ute (C) (MTO)[/url]$301.00 1000/80
The last numbers are your braked towing capacity and the ball weight.
Saeble
Post by Saeble » Tue Jun 10, 2008 11:31 pm
I can make em if you want to go the custom route, I am in SA though.
subybrumby
Post by subybrumby » Wed Jun 11, 2008 9:53 am
I ordered and had a hayman reece put on. I've pulled a Dingo on a trailer from master hire with the bucket and trench digger round the hills of Toowoomba, slow but no problem. The arse of the brumby lifts right off the ground when the dingo is loaded. Just have to be careful breaking, slow and straight.
