Bratgeebah's brake kits for early Subaru's
- Ben
So even after I sell my L series rear discs, and scorpions with tyres to fund this I am still looking at over a k to upgrade?bratgeebah wrote: Parts that I wont provide are
-disks and calipers (front and rear)
-Liberty steering knuckles & ball joints
-hand brake cables
-hand brake levers
-Liberty master cylinders
I will be providing
-new hubs x2
-backing plate boss x2 (Change over predrilled backing plate on request)
-rear brake lines & centrepost supports x2 (front use Liberty)
-means to blank off holes in Lib. master cylinders for MY vehicles.(no need on L)
-Descriptions,pictures and model numbers for hand brake levers etc
-assistance with drive shaft selction
-cv's & doj part numbers
I agree. There's no way you'll ever be able to legally fit those type of nut onto a road car. there's not enough reduncancy, plus thay've got to last on a car a lot longer than a race car.MechaWagon wrote:wildhorse wrote:i would like a set. But am following up on race style centre nuts first. that could be, to me, a better option
*shakes head*
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
It will fit your brumby.wildhorse wrote:Small question G!
What car is this kit for? My brumby is in desperate need for bigger wheels as AWD EJ22 needs better braking and bigger diameter rims. The work you guys are putting in is very substantial and i think it must be appreciated by those knitpickers. If you tell me i can use 5 stud rims on my brumby with this kit, and the price is fair for the effort put in, i am up for a kit.
Cheers for your efforts
As for knitpicking, I'm wondering if you've got your brumby engineered for the EJ22? I know I'm going to have to get it done for my EJ20T conversion anyway on top of this.
I just don't see that point in paying for a part when I'm not going to use it & now I'm especially curious as to why a new brake line is needed back to the car when one already exists?
Instead of that, wouldn't it be a lttle easier for everyone to have a brake line copied like the disc brake rear end version (the drum brake one can be modified to look identical) though fitting the retaining bracket on may be a little difficult (self tapper, spot weld?)
BTW, I'll look into some of the fitments of the later model twin spots to see if they fit up the same way as the early single spots, it may increase the fitment possibilities.
It is obvious we are in different states.wagonist wrote:It will fit your brumby.wildhorse wrote:Small question G!
- WombatRacing
Brakes
So I take it that the people who have posted the most on this topic will be first in with their dollars in hand?
This may not be a cheap conversion but has been very professionally produced. I have done a few of these now but in a much more "backyard" manner involving welding for the splines into the rear hub, which engineers wouldn't like even though they are plenty strong enough. Well done Gee, I hope people now put their money where their mouth is and support your product and you get the return you derserve for your efforts.
- BaronVonChickenPants
Guest
Thanks for the support Legcy tt.
Testing is tomorrow. (Thurs. 12/01/06).
There's a couple of pics of the test cars here: http://community.webshots.com/user/tmac746
Guest
The red one is around 2 inch lower and has Tein coilovers on the front and lowered rear shock mounts with rx rear coilovers and the Brumby is 100mm lower and has had extensive rear suspension mods shorter rear shocks, longer radius rods in the front and has the lowest available wrx spring from Kings in the front. I can dial out the front camber if I want.
I have just purchased a 2.5 engine and loom etc for the Brumby so it will be back off the road again post testing at which time I'm looking at making new 'widetrack' suspension for front and rear with motorsport coilovers all round.
- tim_81coupe
Nice stuff mate, nice stuff.
I've got a set of wheels waiting to go onto my coupe, they look pretty much exactly like the ones on your Leone, off a 99 RX2.5 Lib I think...
So do you have an ETA for production at all? Is this up in the air until testing is complete? Pleeeeassse, I want to be included in the first batch. I have money waiting
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Guest
Stage 1 of testing went well with all components of the kit passing all drive and braking tests. Apart from the hubs everything is ready for manufacture. As you may recall from previous posts my original prototype hub was not hardened. Therefore the test cars included one hardened prototype and one ‘un’hardened prototype. I am hoping to get approval for the un-hardened but need to have some durability tests O.Ked by the engineers first. This should happen in the next couple of weeks so apart from that, the Engineers need to inspect each part off the cars and write up their report and test results for the paper work to all be completed for certification. Shouldn’t take too long. Whilst this is happening I will negotiate final prices on parts and order manufacturing to begin in the next two weeks (on all but the hubs). Pricing will be available as soon the hubs are tested (approx 1 mth given other time constraints in my other business) and the finished products available in 2-3 mths (I hope). In the meantime, I will finish installation instructions and other documentation.
- WombatRacing
Nice work gee, looking forward to hearing how it works out, good luck with all of it, if all goes well I should be able to afford 1 kit from the first batch if theres any left, in 3 months I'll be dancing from leg to leg waiting desperately for some news
Clearly there's been some serious engineering work, some clever thinking and a lot of time, patience and money involved in this, if you don't mind me asking what do you do for a crust?
Jordan.
Jordan.
Guest
