wrx_nut wrote:how did you set up the two speeds? ive still gotta get some pipe bent up for the intake on mine....
Don't worry too much about setting the pump for two speeds, nearly everybody l've talked to about this has told me to run the pump flat out all the time.
l spoke with my local auto elec the other day about the running of this pump, he also tells me alot run using just a relay and fuse to a switch on the dash and wired to the ignition, hmmm, same system as me! he also said that most of the aftermarket pump kits available are set up this way and come complete with these bits included.
Well, not being a genius when it comes to these things, l'll believe him, but then again as l said, when it comes to these things l'm an idiot looking for an easy way out. The point l'm trying to make here is, (to run flatout), when wired this way if the switch is set to on, the pump will turn off and on automatically every time the key is turned, how does this differ from any other system? it doesn't, they all do that, maybe differently but the end result is the same, pump comes on when you start and off when you shut off and thats all l want it to do.
