In my experience the little engines have the mounting points for a cam sensor, but the crank pulley is different. Cam pulleys are the same.mattl200 wrote:to do this you would have to keep the ej22 injectors as ej22s are airflow based the ecu would compinsate for this (assuming the ecu dosent go into limp mode)
and i dont know if this engine has the mounting points for the cam and crank angle sensors or the notches on the cam wheel and crank wheel
Yes, the ECU will compensate for different airflow to some degree, but it will never run well.
Dane.
