New rear suspention
discopotato03
Post by discopotato03 » Thu Jun 07, 2007 2:07 pm
How did you manage to get Impreza front springs onto L front struts or are they similar/same dimensionally ?
Cheers A .
Matt
Post by Matt » Thu Jun 07, 2007 5:33 pm
Below is the camber adjustment kit i am going to hopefully put in on the weekend.
"Claudia"
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Jun 07, 2007 8:32 pm
LegacyTT i am pretty sure that Neville Gosson used Corolla rear shocks on the rear of his lowered MY wagon to give him a good ride. Soft springs and firm shocks make a nice allround ride.
The long road ahead
90brumby
Post by 90brumby » Fri Jun 08, 2007 12:49 am
wheere did u get the kit from and how much is it worth
tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
legacytt
suspension
Post by legacytt » Fri Jun 08, 2007 11:08 am
Thanks for the Corolla shock tip Suby Wan, will give that a try. As for the Impreza bits. I have a 5 stud conversion so a complete Impreza strut/hub on the front and modified rear hub to run the 5 stud brakes and rear handbrake.
Matt
Post by Matt » Sat Jun 09, 2007 6:55 pm
The kit shown above will work. I have just loosely tested it and it will work. You simply need to mount it vertically on the trailing arm (the arm that runs at 45 degrees to the torsion bar) By the look of it should be possible to get 0 degrees camber out of it, or very close to which will be fantastic. I will post pictures tomorrow when i install it and finish it off. I can't wait to give a test drive, new front struts/springs and good camber in the front and back it should handle really nicely.
"Claudia"
Matt
Post by Matt » Sun Jun 10, 2007 7:02 pm
Here is the pics of the kit getting installed. I managed to get almost 0 degrees camber! I am very pleased with the results, it handles way better then had expected.... Highly recommend it to every one.
Roughly in position
During (after welding and sloting)
Finished off
Kit cost about $150 from Kmac Suspension ([url]http://www.k-mac.com.au)[/url]. It is designed for the front control arm mount but works also on the back as i found out.
"Claudia"
90brumby
Post by 90brumby » Sun Jun 10, 2007 7:05 pm
hmmm yes very nice i might have to get 1 of those
Post by El_Freddo » Mon Jun 11, 2007 2:24 pm
Anyone know what insurance or the boys in blue think of these?
Matt
Post by Matt » Mon Jun 11, 2007 4:05 pm
According to K-Mac they are Automotive Engineer designed and apparently don't need approval as long as they are installed by a qualified Mechanic/Engineer. I might look into it further, when i get a chance. Also if done right they would not know, unless they own or know lots about subi's.
"Claudia"
Xtreme_RX
Post by Xtreme_RX » Mon Jun 11, 2007 6:57 pm
May I ask why you fitted this camber kit??
http://www.subiparts.com.au
0438 887 746
Matt
Post by Matt » Mon Jun 11, 2007 7:20 pm
The positive camber on the back with the L series springs was crazy to say the least around 3 degrees. Even with the bike on the back it doesn't even get close to 0 degrees. That was the main reason and other was to improve the handling slightly, which it well and truly did. I am still surprised at the difference it made to the handling, no more rear drifting about.....
Also the other is to hopefully improve the offroad characteristics, i.e wheels getting 100 % traction not like 80% with the tire on crazy angles. I am yet to properly test this.
"Claudia"
Brumby Kid
Post by Brumby Kid » Sun Jan 15, 2012 5:27 pm
So with the bracket made up.
And the Springs purchased.(Are they front? and what year?)
Is there much work involved? (to fit to a brumby?)
I dont want to play around with camber adjustment crap....
Does this matter too much???
Cheers Cam
Dads Car: 02 Impreza WRX STi
spike
Post by spike » Wed Jan 18, 2012 3:26 pm
Brumby Kid wrote:So with the bracket made up.
Cheers Cam
thread from the dead......
if your talking honda springs i think they are front prelude(?) pm steptoe i think he did them
i was under the impression brumbies ran a different type of suspension than L series.
camber with a lift is major. the lift give more positive camber and just screws up all geometry
