Brumby Hard Top Tonneau
Post by El_Freddo » Fri Aug 08, 2014 11:44 pm
Dean.nabbe wrote:now i'm just waiting on the funds to buy the expanding foam and the fibreglass
That's always the fun bit :rolleyes:
Dean.nabbe
Post by Dean.nabbe » Sat Aug 16, 2014 11:04 am
poured the expanding foam today but need to get some more..
i want to have about 25mm above the frame all round, this will give me room to shave it back to a uniform 20mm at the front then slope it down and out for run off..
cut and fitted gas strut mounts, lock rods are being modified to bolt straight to the end of the actuators.. central locking actuators are fitted to the lid and switch is wired inside the cab.(just need to run the wire to the tub and connect it)
i've wired the switch so the lid will lock/unlock via the switch, but will also lock(but not unlock) with the central locking remote... that way i can walk off, press the button and know that everything is locked up and secure but it won't unlock when i unlock the doors(that way i don't have to have the doors locked to stop the lid opening when i drive)
1987 Brumby.
still to come:
2"exhaust
winch bar
Dean.nabbe
Post by Dean.nabbe » Thu Aug 28, 2014 10:20 pm
all the foam is now poured and expanded.. now to shave and shape... will post some before and after photos for you guys when i get it done ;)
1987 Brumby.
still to come:
2"exhaust
winch bar
Post by El_Freddo » Sat Aug 30, 2014 1:29 am
Well, it's now saturday! Don't keep us waiting too long :p
Dean.nabbe
Post by Dean.nabbe » Sat Aug 30, 2014 7:13 pm
started shaving the foam.. not as easy as i expected on my own due to the span..
waiting for a mate to come give me a hand to finish it off..
i plan to shave it to a uniform 20mm above the frame. then leaving approx 1/3 at 20mm, i will shave and slope to 0mm at the back of the frame.
1987 Brumby.
still to come:
2"exhaust
winch bar
Dean.nabbe
Post by Dean.nabbe » Sun Aug 31, 2014 8:58 pm
got the foam shaved down to a uniform 20mm and drew a template of the rough sloping shape to follow..
now the fun begins.. the foam is a lot denser than i expected which made it hard to cut, bring on the belt sander for the rough shape, then i'll hit it gently with a sanding block to make the finer touches..
1987 Brumby.
still to come:
2"exhaust
winch bar
Dean.nabbe
Post by Dean.nabbe » Tue Sep 02, 2014 7:09 pm
i got some shaping done today.. the rough product is finished, now to just do a little bit of tidy up around the raised arc..
the front(closest to the cab) end is at a nice 20mm about the frame and the edges are tapered off to accept the fibreglass.
1987 Brumby.
still to come:
2"exhaust
winch bar
Post by Bantum » Sat Sep 06, 2014 11:55 pm
Looking good there ... :)
Found another one that might interest :
More images to be found here : http://www.ausubaru.com/coppermine/thum ... =94&page=2
Cheers, Bantum ...
Dean.nabbe
Post by Dean.nabbe » Tue Sep 09, 2014 12:48 pm
mine will pivot from the back window, so no wasted tub space ;)
1987 Brumby.
still to come:
2"exhaust
winch bar
Low Rider ...
Post by Bantum » Mon Sep 22, 2014 11:56 pm
Ok - try this one on for size :
More info here : http://z15.invisionfree.com/Mv_Brat_Bru ... topic=1207
Cheers, Bantum ...
Post by El_Freddo » Sun Oct 19, 2014 10:22 pm
^ Checkout those flares!!
Awesome!
Dean.nabbe
Post by Dean.nabbe » Mon Oct 27, 2014 5:12 pm
Sorry it's been so long since I updated.. Been a bit busy to get out in the shed..
First layer of glass is on and looking great.
1987 Brumby.
still to come:
2"exhaust
winch bar
niterida
Post by niterida » Mon Oct 27, 2014 6:20 pm
El_Freddo wrote:^ Checkout those flares!!
Awesome!
Those flares are a neccessity because underneath that particular Brumby is all WRX - crossmembers, struts, brakes, everything :)
No Brumby suspension parts whatsoever............
Dean.nabbe
Post by Dean.nabbe » Tue Oct 28, 2014 9:39 pm
Got the 2nd layer of glass on today, will take some pics for you tomorrow.. Next job will be to fill in some dips and drops with some bog before applying the next layers of glass..
I must admit, I'm kinda proud of myself. It's looking better than I ever expected it to since I've never done anything like this before.
1987 Brumby.
still to come:
2"exhaust
winch bar
Dean.nabbe
Post by Dean.nabbe » Thu Oct 30, 2014 3:54 pm
ok, here are some pics of the fibreglass work in progress..
the glass mat you can see will be the next layer.
because of the frame and foam, the next couple of layers will just be around the edge to give the unsupported sections a bit more strength.. the corners i have put an extra reinforcement piece in as well.. when i'ts all done and cured i will trim it off to level with the bottom of the chrome trim.. then put a pinchweld rubber seal around it..
1987 Brumby.
still to come:
2"exhaust
winch bar
brumbyrunner
Post by brumbyrunner » Sat Nov 01, 2014 6:38 am
Thats coming along nicely mate.
Settlement Creek Racing
Dean.nabbe
Post by Dean.nabbe » Sat Nov 01, 2014 2:31 pm
Thanks mate
1987 Brumby.
still to come:
2"exhaust
winch bar
Dean.nabbe
Post by Dean.nabbe » Mon Nov 03, 2014 9:50 pm
she's off the ute.. tomorrow i will relocate it outside so it can bake in the sun for a few days and really harden up the resin like rock(as advised by a fibreglassing expert).
then i can sand out any big imperfections, give it a coating of spray putty to cover any little imperfections, then paint it..
this was the initial trim so i could take it off the ute. i have since trimmed it to the black line and put the final dress layer of glass..
i put the pinch weld seal on to give you a better idea of the finished edge.. although it is only on the initial cut, so it will actually sit about 10mm higher on the final product.
now i can start cleaning the ute and preparing it to fit the finished lid..
i'll post more photos soon..
1987 Brumby.
still to come:
2"exhaust
winch bar
Venom
Post by Venom » Tue Nov 04, 2014 10:40 am
Awesome work mate.
Proton mouse
Post by Proton mouse » Tue Nov 04, 2014 12:13 pm
Love your work! When do you start taking orders and go into full production? :-)
