build your own EJ AWD for your EA motor
Post by AlpineRaven » Fri Nov 06, 2009 9:56 pm
AlpineRaven wrote:You can use EJ main internals in EA box, it'll fit straight in without problems.
The main housing (including bellhousing) is different in length, as EA box is 12mm shorter around where bellhousing is. I'll upload a picture of EA box tomorrow night.
This is a picture (sorry its poor quality as taken from camera phone) of EA gearbox.. Now you can see the difference between EJ & EA.
Post by El_Freddo » Fri Nov 20, 2009 4:13 pm
Also to add to the mix is the fact that the AWD pinion shaft passes THROUGH the lower gearset shaft. The EA's pinion shaft is solid and shares the same shaft with the lower gear set so there is no interchangability of the AWD rear casing to the EA gearsets OR of the pinion shafts to retain the EA ratios while bolting up the AWD rear casing. Make sense?
Also steptoe, have you updated your first post with what you've foundout through this thread?
Post by steptoe » Sat Nov 21, 2009 1:20 am
no is too short an answer
Post by El_Freddo » Sun Sep 12, 2010 11:07 pm
Hey, can anyone post up the ratios of each gear for the EA 3.7 ratio box, EJ 3.9 (gen 1) box and EJ 3.7 (gen 2) box?
Just for reference ;)
Post by AlpineRaven » Mon Sep 13, 2010 8:48 am
Gen 1 3.9 diff Aus Del model
1st 3.545
2nd 2.111
3rd 1.448
4th 1.088
5th 0.871
Rev 3.416
Final Drive 3.9
Low Range 1.19
Gen 2 Aus Del model (got this information from Subaru Australia)
1st 3.545
2nd 2.111
3rd 1.448
4th 1.088
5th 0.871
Rev 3.416
Final Drive 3.7
Low Range 1.19
L Series 3.7 should be the same as above I believe.
Post by El_Freddo » Tue Sep 14, 2010 1:28 pm
Ok, found this on the super reliable wikipedia:
Stock common L series gearbox:
Gear Ratios: 1st 3.545 2nd 1.947 3rd 1.366 4th .972 5th .780, Rev 3.416 Low Range 1.59
L series AWD lockable centre box ratios:
Gear Ratios: 1st 3.545 2nd 2.111 3rd 1.448 4th 1.088 5th .871, Rev 3.416 Low Range 1.196
Do these seem right?
Post by AlpineRaven » Tue Sep 14, 2010 1:42 pm
El_Freddo wrote:Ok, found this on the super reliable wikipedia:
The L Series AWD box is RX Turbo Box specs..
But the above one seems to be right.
