RSR L.Series Offroader
- Scoobie Doobie
awesome effort, glad to hear its running after an epic built, its so freaking rewarding after so much blood and tears:D
couple of questions....
what were the wiring changes that needed to be done for the apexi ecu. i have a similar issue, car will run on standard ecu but as soon as you plug in the apexi ecu it wont fire. i have the 93-96 rex engine and wiring, sorry as in the four plug ecu harness
earlier in the thread i noticed you installed a new clutch, what type was it??? just curious becasue i'm running a cable clutch setup myself and even though i've just replaced my old one with new heavy duty type i'm still getting a lot of clutch slip. its not a hoon mobile so i do't take off at a zillion mph from a set of light but it still slips
and finally whats in SA, i've only just moved down here from brissy and am way out of the loop in relation to whats happening around town
again nice work8-)
cheers
again nice work8-)
cheers
To tinker or not to tinker that is the question?
It already has 3" lift and the 5 Stud conversion will be done later. Due to time and moving the workshop, I doubt it will happen before I/we go away to SA.guyph_01 wrote:Lol:)
Cool great to here its alive. Can't wait to see what it drives like.. Will it be lifted as mine with a 5stud conversion soonish?
I can't wait to get my rear end done properly:)
There is a few hours gone into her and I'm really happy she is almost there. Few more things to go but should be good.Scoobie Doobie wrote:awesome effort, glad to hear its running after an epic built, its so freaking rewarding after so much blood and tears:D
again nice work8-)
cheers
My engine is the V5 with the 3 large plug ECU. I'm not sure if they will be the same, but Dave located the install instructions (which we never got as mine was secondhand) and it showed which ones need to be done. I have a brand new V4 PFC for my 22B, which I have the instructions inside the box, if you need? or you should be able to find them on the net.
I used a modified clutch from a company over here in WA (unfortunately has now closed down) and they used to strip them down and rebuild using double spring tensions. I'm not sure but I'm guessing there would be other places around Aus that would do this kinda work. If you get it done, I'd highly recommend you strengthen the clutch fork.
As for stuff in SA to do I'd have NFI but I told my boss (he lives over there), I wanted to go camping/fishing/4wding in SA, so he recommended Coffin Bay. Bennie thought this would be a great opportunity for every AUSubaru member that loves getting out and about to meet up, so he has started a thread, so have a search and come and join in and hope to see you there.
Yes he is.. he's a legend.TOONGA wrote:Ah yes the Guru Dave so many cars in WA wouldn't be running if Subarino wasn't around to sort them out.
Do we get video of the engine running?
Sorry, no video of the event. I think you wouldn't have seen much, as the AFM wasn't working the fuel (black smoke) was pouring out the back and filling up the new workshop. Maybe once I have another AFM and finish up a couple of things in the engine bay.
It was great to see... although you should have seen it when the dodgy AFM was in it.. was true rally spec with rotational idle, thick black smoke and fully open exhaust systemtaza wrote:Was great to see it fire upLucky the misfire was just Paul's little stuff up otherwise he wouldn't of left the shop happy last night
Will be good to see the car in action in a few months. I'm excited to see how that gearbox goes and how it holds up against the turbo motor
Now Taza.. remember what happens in the workshop stays in the workshop... lol
I didn't see any 'stuff up' I was just checking the anti-lag feature on the PowerFC
I believe the gearbox will handle it because I'm not going to give this car a thrashing.. I has a nice blue 2 door for that
Which? the L or the 22B? Don't think I'll be taking the 22B to the beach.. would be fun thoughTOONGA wrote:So whats this going to be, your Sunday driver for beach excursions?
Yes, the L will be my every 2nd Sunday beach car until she completely rusts out.
*Winks..* so it worked out well?RSR 555 wrote:Needed some machining to the Dual Range Selector Hub as per what AP did on his box.
RSR 555 wrote:Now to put the goodies in itInstall one RXII Centre Diff Lock.. Pics showing open and Locked positions
RH shot of the completed box.. showing the Centre Diff Lock Lever
LH shot of the completed box.. showing the Vacuum Module for the Centre Diff Lock
Now is just finding some more time to put the engine and box together and then into the car
Awesome read out Paul, Specially this centre diff which Ive never seen before... Getting there and very interested in this task youve done! Keep up the good work.
Thats correct - I was talking to Brett about it lately and I think I installed an circlip as a spacer in that area. Because the bearing was narrower than other one.El_Freddo wrote:Paul do you know if this mod is needed when using a gearbox housing from a Gen 1? I know its not needed in a Gen 2 gearbox but AP said something about his input shaft bearing being different when he did his L series low range swap...
I need a shed!
Nice job. It is amazing you ya feel after all your hard work pays off.
From the east coast . So when are you moving back..LOL.
rtcb65
Redneck Rick.
Redneck Rick.
Thanks.. email?TOONGA wrote:Ive done some gifs for you as well Carmelda
I hope so, it worked perfectly on the bench but the big test will be on the road.. or better still.. offroadAlpineRaven wrote:*Winks..* so it worked out well?
Cheers mate. It's been taking it's time as I'm trying to make it look as factory fit as possible. The extra weight in the front appears to be bringing the front down more but probably fix that with the dual spare wheel carrier on the backAlpineRaven wrote:Awesome read out Paul, Specially this centre diff which Ive never seen before... Getting there and very interested in this task youve done! Keep up the good work.
From memory, I had to get a new bearing that had the EJ O.D. with the EA I.D. and then I had my machinist make a filler/spacer ring to fit prior to the circlip.AlpineRaven wrote:Thats correct - I was talking to Brett about it lately and I think I installed an circlip as a spacer in that area. Because the bearing was narrower than other one.
Thanks Rick and yes it feels great to hear running. Still a little more work to go with the dual range cable and then hooking up the vacuum stuff for the centre diff lock but hopefully it's ready for the SA trip.rtcb65 wrote:Nice job. It is amazing you ya feel after all your hard work pays off.
I'd love to move back home but so much happening over here with the new shop and all. Maybe when I retire
So please correct my ultra-quick review to summarize
But this build is an AJ20 turbo engine mounted to an EJ5MT's bell housing, fitted to an EA82 (L series) dual range case with RX gearsets?
Or is this AWD with RX locking center to a dual range 4x4 with 1.59:1 low on a WRX engine in an L series with WRX brakes on 15" rims?
SICK!!!! that fire-up video sounds wicked BTW!
Glad to glance at this build again and see its coming together with test drives to boot!
The first time I read the dictionary, I thought it was a book about everything.
-S. Wright-
If at first you don't succeed, rev harder!
-S. Wright-
Something closer to this, but I believe on 14 inch rims and no WRX brakes, just really really good L series discs all roundsuparu wrote:Or is this AWD with RX locking center to a dual range 4x4 with 1.59:1 low on a WRX engine in an L series with WRX brakes on 15" rims?
Paul will be able to fill you in more about it!
Yessir.. it's an EJ20 Turbo engine from a 1999 Impreza, now running with a PowerFC ECU, mated to the XT Turbo AWD with Centre Diff Lock box, that has had it's front casing replaced with the 2000 Outback gearbox front halves, plus the box has had the EA82 Low Range fitted at the same time.suparu wrote:So please correct my ultra-quick review to summarize
I used the EA rear casings, so I could retain the L Series gearbox crossmember and tailshaft. From underneath the car, most people couldn't tell what's been changed
Yessir.. you have itsuparu wrote:Or is this AWD with RX locking center to a dual range 4x4 with 1.59:1 low on a WRX engine in an L series with WRX brakes on 15" rims?
The rims are 14" until we change to 5 stud.
Thankyou sir.. I was very pleased when she fired up. Dave (Subarino) worked his magic on the loom and because the 1999 Impreza has the factory fitted immobilizer, Dave had to work a little more than normal.suparu wrote:SICK!!!! that fire-up video sounds wicked BTW!
Test drives aren't too far away.. I would like to sort out the Dual Range cable and the Centre Diff Lock system but this has to wait until the vehicle hoist is fitted in my new shop.
Yeah Bennie.. and really hard to not use these rims when I go 5 stud. I like them and even managed to get 2 spares for the spare wheel carrier.. they might even end up back on the Vortex.El_Freddo wrote:Something closer to this, but I believe on 14 inch rims and no WRX brakes, just really really good L series discs all round
You mean these ones?RSR 555 wrote:really hard to not use these rims when I go 5 stud. I like them and even managed to get 2 spares for the spare wheel carrier.. they might even end up back on the Vortex.
There's a liberty kicking around benders with a set of these rims - so they are out there for the 5 stud
