EJ22 L series engine mounts
Can someone please confirm the mods required to the L series crossmember before dropping in an EJ22, so far I've read it needs to be slotted out 5mm or packed up with washers or the use of tapered perlin washers (whatever they are) I would prefer to do it properly the first time and not end up with broken engine mounts as I've read in other posts, I just need a definative answer on how it should be done or what's needed to do it.
I never slotted my crossmember, i just used 2 good sized washers and she sat down nice. been A ok for over 1 year now!
Hunter S. Thompson
Hunter S. Thompson
- SubaRute
ok if you have the round(lib) engine mounts you have to use some kind of spacer(washers) and prolly elongate the engine mount holes?(correct me if im wrong)
or you can use the square (lib) engine mounts and prolly again elongate the mount holes to suit?
i am currently using the square mounts on my MY crossmember and have elongated the holes to fit.
i hope this answers your questions
im also using square ones in a l member. sorry left that out before
Hunter S. Thompson
Hunter S. Thompson
The slotting isnt neccessary but it just makes the actual fitting of the engine easier. You kindof have to push the mounts in abit to get them to fit initially. Once the engine is seated it makes no difference either way.
The spacing up is only required to stop the front part of the gearbox bellhousing / rear of the engine from occasionally hitting the engine crossmember.
EZ30 L series - Monsterwagon
- stamp_licker
- stamp_licker
- Outback bloke
i havent slotted holes or anything and i keep breaking mounts. Im using the round style at the moment, but i'll be changing to the square ones soon, they seem abit stronger (ie not fluid filled like the round style)
let me know how u go
Thanks for all the advice and answers fellas, I'm just going to run with the square mounts and slotting out a few mil, is there a particular model Liberty the square or round mounts come from so I know what I'm talking about when I try to order them, there's a pair on eBay going for $120.00 item #
130198816290 are they what I'm after ?? there for 94/00 models.
