Don't forget to top up your brake fluid before you drive with the extra power
schultzie wrote:that is what they do stock they are open in all vacume and close at 1psi so that is exactly how a functioning bov should work.
mine sounds very similar to this. i have more torque down low, boost starts earlier and smoother. it spikes to about 5psi then goes down to about 3psi and boost very smoothly up from there up to 7psi. its not an instant hit of boost and thats it like the vf4. when my car is running again i might put the boost controller on just to see how she goes then.Suparoo wrote: The boost starts earlier, but is smoother than with the stock turbo.
How does you TD04 compare as far as when it comes onto boost?
