Speedo Fix
LongtimeAddict
Speedo Fix
Post by LongtimeAddict » Mon Dec 17, 2007 5:45 pm
I'm about to put a 2" lift and 14" speedies on my stock L series. Where do I find the part that makes my speedo read right??????????? :confused:
Matatak
Post by Matatak » Mon Dec 17, 2007 7:24 pm
a handheld GPS..and remember how far out it is..
thats the easiest way neway.
the lift wont cuase ur speedo to go outta wack onyl the trye size.. and if ur only going up a cupple of inches it shuldnt affect it to much.
one of my cars is now reads 3K's above wt im actually doing from going from 175/70 R13's up to 195/65 R14s...altho i enver tested how "accurate" it was before
handling also went up a ton to with the new street tyres ive got :p
wuldnt have a clue how far out my Wagon is but dont think its to bad. ive changed tyres on that heaps to
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
EJ22Ute
Post by EJ22Ute » Mon Dec 17, 2007 8:10 pm
a rough guide would be the % increase in circumference of larger tyres would equal the % increase in actual speed
Phizinza
Post by Phizinza » Wed Dec 19, 2007 10:24 am
I've seen someone use some Adobe program to make up stickers with the speeds out by the right percent to stick over the speedo. Turned out really good looking. Just can't remember where/what/how it was done.
Post by Gannon » Wed Dec 19, 2007 4:29 pm
Phizinza wrote:I've seen someone use some Adobe program to make up stickers with the speeds out by the right percent to stick over the speedo. Turned out really good looking. Just can't remember where/what/how it was done.
I was only thinking this the other day.
Scan a L series dash layout, modify it and take it to a sticker printing place and get it made to stick straight over the old speedo. Could even do it with styled writing and colours
discopotato03
Post by discopotato03 » Wed Dec 19, 2007 6:24 pm
Wouldn't it be easier just to remove the speedo cable drive assembly from the gearbox and fit the appropriate gear to it ? I'd have to look but I think the drive gear has a "D" shaped hole where in fits on the end of the shaft and is retained by a circlip .
Cheers A .
subalex
Post by subalex » Wed Dec 19, 2007 6:32 pm
If you want a professional way to get the speedo, trip meter and odo truly reading accurately then you need to get a speedo ratio box made up. It is a small reduction box screwed onto the gearbox where the speedo cable goes in and your speedo cable screws straight into it instead. My father made one up for me to use, since he's in the business of working with automotive/marine gauges. Might cost something like $100 though. It took him a lot more than that to get the fittings correct the first time.
Richmond Tweed Instruments, Palm Beach (Gold Coast, Qld) 0755 206509.
'91 Sportswagon - 3" lifted, 14" speedys, 27" Nankangs + lots of small details improved. Wouldn't mind some extra grunt from an EJ.
