Problems with weber conversion
suba88
Post by suba88 » Wed Dec 28, 2005 7:30 pm
I'm puting the weber onto an EA82 that has air con and what looks like the fuel return pipe from the weber hits the air con compressor and does not sit onto the adapter plate. Do you think it will be alrite to put 2 adapter plates as long as there is clearance with the bonnet?
Any help will be great. I'll try and get some pics
Thanks Paul
88 L series Sports Wagon, Weber 32/36 carby, 2" Lift Kit, King Springs all round, 14" Desert Rats, 27" Super Trippers, Welded Rear Diff, Dark tint, JVC Mp3 Deck.
BaronVonChickenPants
Post by BaronVonChickenPants » Wed Dec 28, 2005 7:38 pm
Can you get a hose barb with a 45 or 90 degree bend?
Jordan.
suba88
Post by suba88 » Wed Dec 28, 2005 8:24 pm
Have a look at these photos it mite help picture my problem.
http://community.webshots.com/myphotos? ... =530279554
You will see that the plug that holds the little filter in the carby is hitting the air con.
Post by AndrewT » Thu Dec 29, 2005 12:00 am
Strange problem, the guy I bought the carby off originally was running air con, and so was I - had no problems like that....
Have you transferred the carby off the inlet manifold it came on and onto yours? Mabey there's a difference there somewhere.
I never removed the carby from the manifold - I just transferred the entire manifold onto my motor when I got it.
Also, the guy I bought it off had a touring wagon, so did I.....perhaps there is a slight difference with the air-con compressors between models - yours is a sports wagon I think?
Thats all I can think of at the moment anyways :?
PS - that link for the photos doesn't seem to work
MUDRAT
Post by MUDRAT » Thu Dec 29, 2005 12:08 am
As for running two spacers . . . as long as you've got under bonnet clearance it will be good. I ran 30mm carby spacers on my old old EA81 (before mankind had heard of 3" lift kits) and it improved the bottom end torque noticably.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry :cool:
suba88
Post by suba88 » Thu Dec 29, 2005 10:28 pm
I added a second adapter plate and ground a bit off the air con compressor to overcome my first problem. Now the weber is sitting on fine. Just trying to figure out which hoses are needed and which ones to block off.
There is an air pump hose located next to the dizzy it was used on the hitachi carb, can that just be blocked off because i am worried that the pressure might stuff up the air pump. What is the best way to find out which hoses are needed?
thanks Paul
