Brumby Mods
Brumby Mods
Hi All
I'm pretty new at this and am blown away by your collective knowledge. I have a 1990 Brumby, done 200k when I got it. I've replaced the CV's, bought Speedie 14" wheels, torneau cover and SAAS steering wheel. Apart from that pretty standard but I'd like to do some mods. Needs new exhaust system and I want to add power steering and a 2" lift kit, maybe some better shocks. Done a bit of research but like as many tips as possible. I'm reasonably handy but want to know what I should tackle and what I should leave to the experts.
Hi
Adding power steering is as simple as aquiring a power steering pump, lines and rack from any MY series car (brumby, wagon, coupe, sedan) and bolting them in.
2" lift kit order one from BYB or HiRise and bolt it in, shouldn't cause any dramas at all. The instructions are easy to follow with hardly any points to pay special attention to. You basically just need some spanners and a socket set, some good axel stands and a decent hydraulic jack make it easier too.
You will have to take a quick trip to an exhaust shop to have the exhaust repositioned a little - it will hang down too low otherwise.
I'm more familiar with L series shockies and springs but I the good old KYB Strut / Kings Springs combination goes well in the front end of an MY. I beleive you use Gas Riser shockies from some kind of Holden for the rear end (?? somebody correct me on this)
EZ30 L series - Monsterwagon
- tim_81coupe
the need is be, or something liek thattim_81coupe wrote:yeah MGR-504 HQ-WB Holden rear air shocks almost bolt straight in... just need to use an adaptor to mount the top pin to the two bolt holes on the body.
Can post a shockie mount picture if need be.
just post that pic
 (please)
 (please)Wagon is no longer....
LOL thats kinda expensive for a want of Power Steering.
ive got the bracket and pump off my old motor in the shed. maybe more. i aint sure nemore wt i kept off my motor.
Speak to SubGiraffe aswell he shuld have some leftovers for P/Steering aswell.
we are both in Perth aswell
- subgiraffe
yeah, got a ps pump and bracket if you need. If the steering is heavy, there is something wrong/worn on your front end.
When I lifted my brumby I put in adjustable radius rods and pushed the castor a closer to neutral, the steering is nice and light, yet stable at high speed.
Someone on the board was making adjustable castor rods, can't remember who, I believe I bought mine before the board rebuild.....
- INEEDABEER
Land Cruiser FJ-45 shocks will go in with no mods.As long as you've done the lift every where else there is no need for bracket extensions for the shock mounts.tim_81coupe wrote:yeah MGR-504 HQ-WB Holden rear air shocks almost bolt straight in... just need to use an adaptor to mount the top pin to the two bolt holes on the body.
]Hey I know Jack Schitte![/SIZE]
						- INEEDABEER
The Landcruiser shocks should be right as i believe they are 3" longer?
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
- brumbyrunner
- Proton mouse
I used front FJ40-45 cruiser shocks for the rear of my 84 'MY' wagon. Found out the loud way why you dont use the lift kit shocky extensions....with a bit of a load on board and hitting a bump there would be an almighty 'BANG', removed extensions and noise went. Now all i hear is the scream of the EA81 in full song!!!
						So the FJ40/FJ45 shocks have the pin top and eye bottom just like the brumby, or do I need to salvage the pin out of the standard shocks?
Oh and should I go heavy duty or just stick with the basic monroe ones?
Thanks
Thanks
2002 Impreza GX Hatch: Dents, Scratches, Missing inside wheel arch, Barely attached front bumper.
1983 Brumby: Currently being rebuilt.
You will have to save the pin type and i have heard of people using second hand standard ones with great sucess....
"Claudia"
"Claudia"
You can make Adjustable Castors youself from EA falcons Castors (I may be incorrect on series), as they have a nice long amount of thread to play with, and they are reasonably thick.subgiraffe wrote:Someone on the board was making adjustable castor rods, can't remember who, I believe I bought mine before the board rebuild.....
______________________________________________________________________________________________________________
I hope the $700 power steering set came with a whole car mate, lol, that is terribly expensive. Hope you find one a LOT cheaper elswhere.
L series racks bolt straight in too, with small mods. You need to use MY Tie rod ends to the rack ends and shorten the rack ends about 8-10mm to allow for adjustment. The rack may need slight spacing from the cross member (3 washers should do) to allow it to fit without steering boots rubbing on front the control arms.
Steering: Have you checked the strut tower tops to see if they are rubbing on anything. My Uncle had that problem with the steering being heavy.
If you wanting to go offroad, an L series Dual range Gearbox is a good upgrade (bolts in with minor mods) for a lower low range than MY boxes.
Cameron was making Adjustable Castor Rods at one stage. I haven't seen him online for a little while PM him and see how you go? Or you can modify XD Falcon Rods to fit?
"Claudia"
"Claudia"
- INEEDABEER
FJ 45 cruiser shocks go straight in ,no mods and no lift extension.From memory I think you need to take one of the pins out.tim_81coupe wrote:yeah MGR-504 HQ-WB Holden rear air shocks almost bolt straight in... just need to use an adaptor to mount the top pin to the two bolt holes on the body.
