Ea82 Carb dyno results
41kW peak power.
Sorry no A/F or RPM trace.
How does this compare to other people's results ?
Wow thats low, i think they were 66kw from factory. How many Ks on it?
Have you got any mods?
I have to admit, mine is feeling very sluggish at 285,000km
Thats sounds about right....theres a 20-30Kw loss from flywheel reading to atw reading. And dynos aren`t that acurate...they don`t have to be to be used as what they are designed for, a tuning tool.
Why did you dyno it ? was there another issue ?
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
heres the thread on my ea82t that i got dynoed a month or so ago. 72kw i think it was. 100hp anyway.
http://www.ausubaru.com.au/showthread.p ... dyno+ea82t
That was FWHP.  Local club was having a dyno day, so just did it out of curiosity.
Why is there so much drivetrain loss ? Is it to do with the transfer case being in the mix ? 30% seems high for drivetrain losses compared to other cars.
I've been looking at the "simple" power adding stuff - coil, exhaust etc. How do you diagnose what's hurting you most ? Apart from throwing something on and seeing if there's a difference ? i.e. what are the signs that your coil is substandard ? Exhaust too restrictive, etc. ?
OK thats calculated FWHP...so yeah thats low !
Driveline losses on a Subaru AWD set-up I know to be ~20-30Kw....its not a percentage but a constant, if yours was Front wheel drive it maybe should have been less. It does depend on driveline, wheels and tyres, pressures , selected gear, dyno set-up etc
How many K`s has it done ? how does it drive ? 4wd thru sand ok ?
OS
OS
Oops.  Was used to rear-wheel hp as "rwhp", so converted that to front-wheel hp as "fwhp" - the 41kw was at the wheels.
Haven't tried 4wd through sand.
400k on the chassis (and probably gearbox), 200 k on the engine.
Drives OK, handles like a pig (should be fixing that with strut tops). Can still light up a front wheel if I put the boot in when taking off
about right power figure then as i said earlier
OS
OS
