Fuel lines for EA82T conversion
I'm aware the conversion to an EA82T in my L wagon requires the MPFI fuel tank and pump - but what about fuel lines? I realise the MPFI engine requires higher fuel pressure so... Will the Carb EA82 lines do the job OR should I see if I can swap the MPFI lines from the donor car; or should I get some new ones that would have to be bent to shape??? OR Could I use suitable rubber hose instead...?
Any insight would be appreciated
Timmo
Timmo
- Suby Wan Kenobi
The std L series lines will do the trick but you might want to use the tank breather hose as the return line and switch it over down the back near the tank for the breather hose. If you dont switch it down the back as well fuel will poor out your charcoal canister.
The long road ahead
The long road ahead
- Suby Wan Kenobi
- Suby Wan Kenobi
