EJ conversion: simple question about gearbox clearance without lift kit
Post by El_Freddo » Mon Aug 07, 2006 2:35 pm
If i was going to put the Ej gearbox in with the conversion, does the gearbox have enough clearance to fit in without a lift kit?
Or will the gearbox and engine cross members need to be spaced a little bit?
MUDRAT
Post by MUDRAT » Mon Aug 07, 2006 3:39 pm
Which gearbox do you plan to use?
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry :cool:
Post by steptoe » Mon Aug 07, 2006 8:09 pm
if it helps, until right advice comes along.... have seen EJ20 and its awd box in a std height Brumby
MUDRAT
Post by MUDRAT » Mon Aug 07, 2006 10:13 pm
I can tell you an auto definately won't fit.
Post by El_Freddo » Tue Aug 08, 2006 12:17 pm
i'd like to get a hi/lo range liberty or better... autos are for lazy people... D for drag i say... ;)
Ultimately i'll be running with a 3 inch lift kit and use the standard wheel size from the donor car that the box came from...
_curlie_
Post by _curlie_ » Tue Aug 08, 2006 1:06 pm
i have a ej22 in my L series and i kept the L series gearbox
89 L series 14"rims 27x8½" tyres, 2" lift kit,
EJ 22 motor,
simmo
Post by simmo » Tue Aug 08, 2006 7:10 pm
i'm getting through my EJ20 conversion into the brumby an the liberty single range 3.9 box fits at standard height....
Post by El_Freddo » Sun Aug 13, 2006 2:44 pm
Nice, that's what i like to hear... hopefully a dual range awd box isn't much bigger than a single range... Now to get some money...
vladrulli
Post by vladrulli » Sun Aug 13, 2006 9:00 pm
my original conversion was ej20t+4eat and everything bolted up without any major mods... transmission fitted really well and no tailshaft mods were required....
now I've fried the auto and in the process of putting in an awd dual-range box... I'm having problems with tailshaft clearence because of the shifter...
the car was an auto originally and I got the shift stick and brackets out of the donor car (Impreza '97) and it looks like there is not enough room to let the shifter-brackets and tailshaft to fit properly without mods to the tunnel... has anyone experinced this problem? how did you deal with it?
also... it looks like I have to lengthen the tailshaft... what lenght do I have to add to the auto shaft in order for it to fit the dual-range box? 120mm - or was that for some other gearboxes?
1997 Subaru Legacy Outback
1989 Subaru GL Coupe EJ20G, FMIC, awd dual-range - SOLD
