don't bother using forged pistons and internals... its not really worth the money unless you plan to wind this thing up to 9k rpm on a regular basis...
just go with high CR ea71 pistons... a proven and cheap mod(as far as parts go)
if you want MPFI heads like the ram ones just get normal ea81 turbo heads... i don't know what that would do to the CR though... plaining those turbo heads would probably help boost it more... or maybe even shave the block a bit... if you make a custom intake manifold than expect a nice boost in power... there is a water passage running through the stock intake... helps during cold starts and such...
if you redirect it so it doesn't pass through the intake manifold (don't just block them off) than you can get a nice boost in power...
if you actually do this stuff you'll have one heck of a peppy ea81... no it won't be a match to a decent ejxx... but hey, you're gonna have something to boast about!
everybody does the ejxx conversion (heck i've got a ej22 and/or ej22t lined up for the 79 brat) but nobody cares for the eaxx's... it'd be way more original! plus you'll be able to laugh at all these guys when they bust a timing belt...
