Rear Hand Brake on an Ea82
- Chris_Rogers
- Chris_Rogers
I'll be wiating with baited breath to see that.
Have you sat a console over the top yet though?
Also, I've had this brilliant idea with the help of a friend where you use the existing L handbrake & cables, plus the EJ cables
How's this for a handbrake idea (Yes, I'm slutting this idea around)
No mods required to the factory lever.
No mods required to the centre console
No extra holes to be drilled all the way through the floor.
Extra mounts for the cables are required though.
There is no bindage with this setup (ie the cables aren't on too tight a bend)
Now to figure out how to join the 2 cables together....
new longer inner cable runs at $47ea, or a complete new one runs at $80ea
- Chris_Rogers
yes I have. it fits nicely and works. I'm considering swapping the boot over for mine just for neatness- the WRX one fits in teh hole and works. only change I have to make is the rear of the console. which I'll modify/rebuild to handle the rear exiting cables.
your idea is good however mine needs an engineers plate to be 110% road legal so I'm doing it as per factory.
pics shortly.
pics shortly.
- Chris_Rogers
- Loyale 2.7 Turbo
I Wish to Thank you for Such Great information, and Kindly Ask you for More Updated Information about how the Rear e-Brake System from the Honda, performs in the Subie.ToyRX wrote:... honda part is a bolt on to existing backing plate etc. Apparently the story goes that Honda and Subaru used the same brake component supplier in the 80's ...
I Got Rid of the Failing front e-Brake on my BumbleBeast and my First Idea was to Use a "Brake Lock" but I Dismissed that Idea...
More info about that, ~► Here.
Now I'll Start Searching and Collecting all the Parts Needed to do that Honda Rear e-Brake Retrofitting.
I Really Need to do that Rear e-Brake Retrofit, so any information, Part Numbers, Pictures and any Advice will be Greatly Appreciated.
Kind Regards.
The easiest way i have to fit a hand brake to the rear is quite simply , is buy a crossbred kit. Fits liberty brakes straight on.
rtcb65
Redneck Rick.
Redneck Rick.
You looked where this guy is?
I've done this conversion, but the car isn't running yet, so I've no idea how well it works on the street.
Parts needed:
Subaru Leone/Vortex (XT):
rear brake rotors
hubs (4WD/2WD type depending on your car)
rear brake pads
rear disc brake backing plate
rear caliper carrier (the fixed part that bolts to the backing plate)
rear spring slips that hold the pad into the caliper
Honda Prelude (series 2 facelifted version) BA3/4/5/7 from the early 1990s.
rear caliper (the part with the piston & handbrake mechanism)
This one:
I saw an Integra of a similar age that the rear end looked similar
The next model Integra may be the same also
Custom:
rear flexible brake line (the Honda one uses a banjo bolt, Subaru an in-line fitting)
handbrake cables (if you want to retain the Subaru handbrake lever)
The complete Honda unit won't fit onto the car, but the Honda caliper fits onto the Subaru carrier.
You'll need to trim the Subaru pad springs on the corners to fit inside the Honda caliper (when you put the 2 together over the brake rotor you'll see where it interferes)
In the centre of the back side of one of the Honda pads is a small pin. This is to stop the piston spinning (this is how the handbrake tension is adjusted). To replicate this, I then used a cut down split pin (similar sized to the pin on the Honda pad) pressed/hammered into a hole drilled in the correct position on the back of the Subaru pads.
I also fitted the left side Honda caliper onto the right side of the car & vice versa. This aims the handbrake cable over the top of the suspension to aim forwards (they aim downwards on the Honda).
That's it for fitting the caliper.
I didn't want to wreck the interior look, so to keep the Subaru handbrake lever (all these other conversion using a lever from a different car look crap to me), I had a cable shop make me up some long cables with the Subaru fittings on the lever end & the Honda fitting on the brake end.
The cables go forward in the transmission tunnel to where it starts to widen out & then I've turned them back down the tunnel onto the opposite side. This means the left side cable operates the right side caliper & vice versa. The cables cross over on top of the "centre diff" part of the gearbox.
To attach the cables, I drilled holes in the floor, and used "nutserts" & "P-clips" along the tunnel & on the rear suspension.
The most expensive part of the this conversion was the cables at about AUD$120. Brake lines were about AUD$30ea. Calipers from the wreckers about AUD$20
On top of this is probably new seals & pads.
Parts needed:
rear brake rotors
rear brake pads
This one:
Custom:
Current rides:
JDM GTII Touring wagon
88 RX Turbo Full-time 4wd touring wagon project - 97 Toyota Caldina GTT (turbo 4wd WRX eater:twisted:) - Hyundai Excel Rally Car:???:
Previous rides:
96 Toyota Caldina wagon
Previous rides:
- Loyale 2.7 Turbo
Thank you for Such Great information, which will be Very Useful!
I Really appreciate that you took your Time to explain all that to me.
My BumbleBeast Subaru already has Rear Disc Brakes, the Front e-Brake was giving too much problems to me,
So I got Rid Permanently from it, as you can see, ~►here.
(So Sorry for the Yellow Text, the Background colour was Dark Grey when I Typed that, you will need to Highlight that text to become Readable)
Also, we have many of these...
I Have Read in This ~► Thread, that the Rear Disc brake's Calipers from Nissan 200 SX will work on the Subaru
"L" Series Rear Discs Too... But people wrote on the USMB that the ones from the Nissan 240 SX will be a
Direct Fit.
- What do you Think About that?
- Does anybody here Retrofitted Nissan's Calipers in "L" Series Subarus?
- Which Retrofitting is Better, the Nissan's (240 SX) or the Honda's (Accord / Prelude) Calipers?
Thank you in Advance for any Feedback... I Really Need my BumbleBeast to be Safe to Drive AND Parking,
because my Li'l Country is Extremly mountainous and we Have too Many Uphills / Downhills on Streets \ Roads
where sometimes I Need to Park; as you can see in the Following Picture of the Capital Twin Cities:
I Drive on City and Paved Roads / Highways During Week Days, and offroading on Weekends.
Kind Regards.
...Preludes Here, that opens wider the expectatives of Finding the Right Parts for my Retrofitting.wagonist wrote:...
This one:
Direct Fit.
Kind Regards.
We didn't get the 240SX in this country, and the equivalent Silvia was only a low volume 2nd hand import from Japan, so are impossible to find at the wreckers.
Therefore I can't comment on the suitability of the Nissan calipers and is the reason I went with the Honda version when I found out it fitted.
Current rides:
Previous rides:
Previous rides:
- discopotato03
- Loyale 2.7 Turbo
i looked into some kits, came up the same price as rx disks which i couldnt afford.
The only reason i can see about a rear hand brake is for hand break turns and you want hydro for that.
if you want it to hold your car look for a line locker i think they were called, put hydraulic pressure though the full system
or a disk on the drive shaft, either or
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Going around in circles are we now??RSR 555 wrote:showthread.php?t=3325
Thought I'd point that out.
- Loyale 2.7 Turbo
Yes, I Noticed that the Link is for this same Thread...RSR 555 wrote:showthread.php?t=3325
Well, I'm Still Searching for the Parts to do the Retrofitting.
Kind Regards.
To get rid of the old E brake get one of these, locks all four wheels
if you want it on the rear for rallying well thats another thing all together
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- Loyale 2.7 Turbo
The Line Locker... it was Hard to View the Link but I Found it:
~► http://trickshiftperformance.com.au/zen ... cts_id=120
I Already had a similar Idea, but was Dismissed.
Look Here ~► http://www.ultimatesubaru.org/forum/sho ... p?t=130339
Kind Regards.
Kind Regards.
