Ea81 S/C
- Scheffer1986
Ea81 S/C
I wanna s/c my rebuilt ea81 and blow thru a 32/36 dgev weber, any one done any thing simular using a s/c
- TOONGA
I take it by S/C you mean supercharge or supercharger, and you want to do that to an EA81.
I would love to see that running. are you going suck / draw through or blow through?
USMB
http://www.ultimatesubaru.org/forum/sho ... hp?t=72291
USMB
TOONGA wrote:I take it by S/C you mean supercharge or supercharger, and you want to do that to an EA81.
I'm going out on a limb here and saying blow throughScheffer1986 wrote:I wanna s/c my rebuilt ea81 and blow thru a 32/36 dgev weber, any one done any thing simular using a s/c
Hahahahahaha.. I was just having a joke just as I thought the question was (no disrespect to Scheffer1986). I could never see a s/c work as a blow through.. you got to think of what happens to the forced air when (like Jonno says) the flutterbys are shut.. there is only 2 places.. out week joins or through the jets and breathers in the carby. Either way you're not going to have a very healthy running engine. The case is different when the engine is direct injection and the s/c is electronic controlled (as in the case of the Toyota's).
Scheffer1986.. why you looking to use a s/c for forced induction? IMO it's a lot easier/cheaper to use a turbo. You can use carby (albeit designed for the purpose) or without too much expense you can setup a fuel only ECU unit. I understand the idea of having low down torque but this can be done with ball bearing turbos and the correct a/r on the exhaust housing.
ive heard and seen photos of supercharged EA81 and 82 i expect the usmb link would help
Planes mostly but carby is not the way to go, sorry, too much f***ing around to work it, with blow through carbies you NEED a wastegate that works when off throttle or carby goes pop =)
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Why is a supercharged carb'd motor hard? Suck through of course.
You don't need anything like a rising rate fuel supply, and because the SC is more or less locked to the speed of the engine the results are predictable.
Use a wideband O2 setup and get a jetting kit and you're set. Probably take a few hours of screaming around while keeping an eye on the A/F ratio (or just logging it using a notebook), swapping jets and taking note it'd be no more difficult really than dialing in an N/A carb'd motor.
- Scheffer1986
Ea81 s/c
I'm already running a weber and you can buy a plenum that sits over it sealing the carbs vents and a small s/c would be plenty for a 1.8lt then i can intercool i was gonna draw thru with a eaton m45 and run a side draft su or weber but they lack acce pumps , and is needed at high rpm
- littlewhiteute
When going blow though, the carb should be inside a box for best results, stops boost fuel leaks out via the throttle shafts.
Carb should also have boost referenced power valve, nitrophyl float not brass.
SU carbs and all Webers works fine on suck through, and they all have accelerator pumps.
Webers as a fixed choke carb have an accelerator pump circuit.
SU carbs, known as CD or CV (constant depression or constant vacuum) carbs have the dampened effect on the piston rising causing a heavier draw on the jet for acceleration enrichment.
Gary
Gary
- Scheffer1986
Stuff to use
I am tossy up now between turbo or s/c go to http://www.turbogemini.com and have a look at some of his stuff can be easily modded for any thing turbo kit with blow thru carb looks nice or even just the blow thru carby kit and a centrifugal s/c some pipe work intercooler and i'm done
This would be cool
Yeah Gannon, that aircraft engine does look pretty cool.. I don't know about the black oil underneath though
that s/c looks like the Vortech system??
i think its paint, the yellow is ontop of an orignial black trolleyRSR 555 wrote:I don't know about the black oil underneath though
GETDIRTYCLOTHING
GETDIRTYCLOTHING
