Bigger Alternator?
Bigger Alternator?
Does anyone know what higher amp Alternators will fit in the original position on a MY/Brumby? Just looking at setting up dual batteries and will need a decent alternator to charge it. I have already done a search with little info.
Thanks
Matt
Thanks
Matt
"Claudia"
"Claudia"
I looked into this a while ago.... there was a few options about... One of which was to get the alternator re-wound internally. This was going to be pricey and i was warned that the alternator was going to have to spin faster in order to charge. Basically wasn;t going to charge unless i was over around 2000 rpm. I didn't want that.
I ended up installing a 2nd alternator. I didn't have air con... and belive it or not... a second alternator can easily be retrofitted to the air con bracket and off the belt pully for it. An adjustable bracket, to be able to tension the belt, was the only hard thing about it.
Pic: http://community.webshots.com/photo/374 ... 5049CnZBOW
This created more than enough power.... i was very happy with it.
Since converting to an ej22 engine the alternator is a little more powerfull but i still would love to go back with a dual set up.
Dave
Dave
I recall seeing on either USMB or NASIOC some info on fitting either a GM or Ford Alt. It was up around the 200 Amp rating. It was a pretty big sucker, but if your aircon compressor is mounted 'inside' I believe it will still fit. They had a bit of stuffing around to get a pulley to fit but did end up with a good solution.
Pete you don't have a link to tell what sort of altenator will fit up. I figure there will be something because they are all similiar sizes just different current ratings.
Stinky i do have Air con and plan on keeping it due to some days up this end of the country i gets warm
(Townsville)
"Claudia"
"Claudia"
- BaronVonChickenPants
- dirty skirt
I believe that the XT6 had a 90A alternator, (the l series uses a 60A doesnt it?)
I also have a part number for a 90A altenator that came with the rally spec RX turbo's. but i dont think that it was avaliable to the general public.
You don't have the part number easily accessible do you, Suparoo? It might be worth punching in to a computer and seeing whether it comes up? And you don't know what model Nissan anyone? Has anyone got in pics of one in there car?
"Claudia"
"Claudia"
