EJ20G boost levels
EJ20G boost levels
hey all,
just curious here.
What is the stock JDM EJ20G boost level?
And what sort of level can i go up to safely for everyday driving?
Also, at what level is boost cut?
Im looking to wind a tad more boost into the wagon.
Im obviously going to install a boost gauge also. I have a bleed valve type boost controller here. Will this work ok? (bar the obvious spiking etc)
thanks heaps
just curious here.
thanks heaps
- Captain Obvious
check capital letter^^^^^^Keffa wrote:hey all,
just curious here.
What is the stock JDM EJ20G boost level? AROUND 10-11 PSI
And what sort of level can i go up to safely for everyday driving? WHY WOULD NEED TO FACTORY IS HEAPS
Also, at what level is boost cut? I BELIEVE IT 14PSI?? CORRECT ME IF IM WRONG!!
nah factory is not heaps
it's only heaps in the eye's of people driving non-turbo cars. I find no matter what car I'm driving after a little while I always want more power!
EZ30 L series - Monsterwagon
thanks heaps CO..hrmmm id really like to boost her up some more!
i'll have to get a boost gauge hooked up and see whats going on.
and yeah as tmack said....i wanna go abit quicker
thnaks so far fellas
go quicker to get it confiscated quicker...clever assed move
sorry for my bluntness
My Ej20 G has run up to 21 psi boost on very special occasions on avgas with a vf 22 ihi turbo
It hauls on this level let me you
Motor is standard part from turbo, intake too turbo 3 inch dump to tip, ecu and dual pressure boost controler.
As a daily thing it runs a much more seddate 14psi/7 psi
Mind you i am running a link ecu in mine
So many optioins not enough time or money
boost cut for the ej20g is not govend by a maxium pressure rather a maxium amount of air flow from the air flow meter
this being the case them boost cut defenders dont work
just to save people the trouble of getting one to find out it dosent work
vos chipped ecu is the go if u have a 16bit rs ecu
17pounds of the good stuff no speed limit
link = too simple and basic, and not many tuners like using it....i had mny link tuned and it contributed to my motor blowing up.... autronics ftw
PowerFC ftw! plug n play, easy to manage yourself, tuners love em
(from what I've heard)
ok, here are my findings....
stock jap spec rs boost is 6-7psi.
wound her up to 12, spiking to 14 and the thing is astoundingly quicker. Then wound abit more into her so it was sitting level on 14psi, bullshit quick for a l-series haha.
Havent hit boost cut yet.
Vf35 + 2bar = Skidz
Hunter S. Thompson
Hunter S. Thompson
wow Alex, you have inspired me to put the boost gauge and controller I have sitting here!
