L series standard power window system
Post by AndrewT » Sun Apr 27, 2008 12:45 am
Anyone have any details on this....
I have a non-electric window L series and I have a set of 4 electric window doors ready to put onto the car complete with the switches on the doors, and the main switch cluster on the driver's door....but I don't have the electric control unit for in the car. I think theres a little box usually located under the drivers seat with a wiring harness? But I haven't spent any time tracing stuff in my touring wagon to compare - hoping somebody can just volunteer the information so I dont have to :)
Basically just need to know what to grab from a wreck to make this work.
thanks in advance!
SuBaRiNo
Post by SuBaRiNo » Sun Apr 27, 2008 11:11 am
Easier to put afternarket switches in with the factory motor and make the module up using relays... etc. Thats what i did. Less problems in the long run in my opinion.
Dave
Post by AndrewT » Sun Apr 27, 2008 6:35 pm
That is a good idea. I suppose it wouldn't be too difficult to do that. Think I'll have abit of a shop around for some nice switches etc this week!
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Apr 29, 2008 7:21 pm
The control for the windows is under the passenger seat and is a separate loom from the main loom. You may even have the plug on your loom to just plug it in. The main problem you have with the L series power windows is the switches themselves but if you give the contacts a reall good clean, soak em in CLR or something similar, and then apply a small amount of lube you will get another 5years or so out of em before they play up again.
The long road ahead
Post by AndrewT » Tue Apr 29, 2008 8:24 pm
Cool thanks for the tip, although I'm sure all the door switches on these doors I have here were all working fine...right up until the car was rolled 3 times :)
