Power losses
Power losses
When im driving at night time with the stereo cranked and lightn on, every time the sub starts going all the lights in the car dim.
I am thinking that either the alternator is on its way out or the battery is nearly stuffed??
Ideas?
Thanks, Jarrod
Ideas?
Thanks, Jarrod
Hunter S. Thompson
Hunter S. Thompson
It goes on the negative (??) side of the power input for the amp. Put it wherever you want, as long as its in line with the amp. Its a capacitor, so it stores energy, and uses some of that to cope with the bass hits. Smooths out the voltage drops and peaks in the system, and your sub will have better response.Suby Roo wrote:Thats pretty cool but how does it work?? and where do i put it at lol
i have a mate that uses one and he loves it. was simple to install.
Hunter S. Thompson
Hunter S. Thompson
Or turn the head lights offSuby Roo wrote:I could.....
Nah too much fun with it on!
Im pretty sure they go inline with the amps positive input.
Ive read mixed reviews of them on car audio forums, id do some research first. You might be better off doing an alternator upgrade or a bigger battery or both, the capacitors seem like a band aid fix.
just get the cap and you will be fine
Hunter S. Thompson
Hunter S. Thompson
