liberty reverse lights
Posted: Tue Oct 02, 2007 10:16 pm
by Chris_Rogers
how do these things work?
I have two wires - blk/yel (feeds TCU) and brn/yel that feeds the reverse lights. putting the car in reverse connects the two but for the life of me I have no reverse lights. L series reverse wire is lt grn and that is correct.
are the liberty rev lights relayed??
Posted: Wed Oct 03, 2007 6:52 am
by AlpineRaven
are you sure the switch is okay on the gearbox?
Posted: Wed Oct 03, 2007 12:31 pm
by stamp_licker
Chris the l ones are relayed.Mine i wired from the ej auto loom for the reverse light[one wire,brown i think] and into the l reverse wire [green/black]that connected to the l auto shifter.When i was trying to work out what wire it was i could here a relay clicking on and off .
Posted: Wed Oct 03, 2007 6:51 pm
by Chris_Rogers
ok I went past that. mine taps directly into the L reverse wire int eh kickpanel. think I know where its broke now that I have the diagrams for the legacy. I have one wire confused. need to tear a harness down again to find one blk/yel wire that feeds the switch. everything else works
Posted: Wed Oct 03, 2007 7:42 pm
by Chris_Rogers
found it!
missed a wire when I taped the main harness. have lights now. :) there are two blk/yel wires in that main lead - one feeds the trans earth via the TCU and the other feeds the rev switch.
does anyone have a L series fuse panel layout in english. mine is in japanese and I need to find 4 IGN circuits..
Posted: Wed Oct 03, 2007 8:06 pm
by stamp_licker
yes. top as you open it
Lheater/ heater/ stop room/ position/ hazard clock horn/ tail lic illum/ head lh/head rh
O 15a /15a /15a / 15a / 15a / 15a / 15a / 15a
Acharge/ back turn [4wd at]/ ign coil fuel/ meter eng/ radio/ cigar/ fan/ wiper washer/
D 15a / 15a / 15a / 15a / 15a/ 15a/15a/20a /
B
Ar-def/ r-def/ /dr lock/ height /spare / spare
T 15a/15a/ /20a /15a /15a / 15a
T
E
R
Y
Posted: Wed Oct 03, 2007 8:13 pm
by Chris_Rogers
thanks for that :)
Posted: Wed Oct 03, 2007 9:48 pm
by Chris_Rogers
reverse lights - SORTED! removed the original wiring from the L series manual wiring. still can't work out why the solenoid is chattering in the gearbox though... (ideas?)
Posted: Thu Oct 04, 2007 1:13 am
by vincentvega
which solenoid is chattering?
Posted: Thu Oct 04, 2007 7:47 am
by Chris_Rogers
can't tell- its in the gearbox though.only seems to be in reverse.
Posted: Thu Oct 04, 2007 10:01 am
by stamp_licker
Can't help with the noise,my dutyC is hooked up to a switch and i don't hear any noise engaging or disengaging from the solnoid.Weird.
Posted: Thu Oct 04, 2007 10:11 am
by vincentvega
is this wile the ignition is on but the engine is not running?
I have heard this in a few different cars. Dont worry about it, you will find it goes away once the engine is running and you have some line pressure
Posted: Thu Oct 04, 2007 3:44 pm
by Chris_Rogers
it is. can't tell if it is there when the car is running. can't hear over the open exhaust - drives and shifts gears so to me nothing is wrong with it.
I'll have another listen tonight when I do the speedo drive.
ta!
