EA82 5MT FTAWD Wiring diagram
BrennyV
Post by BrennyV » Mon Aug 13, 2007 5:11 pm
He lads, just seen if anyone has the diagram as id like to hook up all the dash lights.
Really need to know when the diff lock is on or off and also the rest of the wiring coming from the box. I have the cluster to suit just no idea on wiring.
2ndly I found myself a set of solenoids to actuate the diff locker and noticed were the factory mount is that there is a plug that suits the solenoids? Can this be used and were dose the wiring goto?
Thanks in advance
Brendan
Hunter S. Thompson
legacytt
Wiring
Post by legacytt » Tue Aug 14, 2007 3:36 pm
One option if you keep the Aus cluster you can wire the diff lock sensor through the 4wd circuit so the green 4wd lights only come on when the diff lock is engaged. I did this when I had one of the AWD boxes in an L series. As for the facorty wiring there may be a corresponding plug near the gearshifter for the difflock switch etc.
BrennyV
Post by BrennyV » Tue Aug 14, 2007 6:10 pm
legacytt wrote: As for the facorty wiring there may be a corresponding plug near the gearshifter for the difflock switch etc.
might have a nuther look round.. really wanna get the diff lock light to come on ;)
Hunter S. Thompson
Fang
Post by Fang » Tue Aug 14, 2007 6:18 pm
Brendan - your car has a 2WD cluster at the moment doesnt it? Does it have a tach now?
BrennyV
Post by BrennyV » Wed Aug 15, 2007 10:59 am
i had the 2wd cluster with rev tach, and i have mod'd it with the ftawd centre cluster also.
Hunter S. Thompson
BlackMale
Post by BlackMale » Wed Oct 03, 2007 5:30 pm
Bump.
Any other input?
I do not have the same issues as 4Muff however would welcome some possible solutions.
legacytt - i do like this idea (as a backup though).
Thanks
BrennyV
Post by BrennyV » Wed Oct 03, 2007 6:01 pm
would be good. i might just run all new wiring i think? from box to cluster. bit of a waste puttn in the awd diff lock cluster if i aint using it ;)
Hunter S. Thompson
