L-series central locking
Post by Alex » Wed Nov 30, 2005 10:49 pm
Hey guys
got a 90 subie L-series wagon, which i wanna put central locking into, i have tried before but there aint enuf space to fit the motor thingy's in.
Has anyone put it in before, and how did they do it?
Fang
Post by Fang » Wed Nov 30, 2005 11:23 pm
Yup - and it involved some grinding/cutting. An absolute mongrel of a job - had wires going all over the car - even have my hatch as an actuator.
We grinded/cut - then we screwed the actuator in. Some of those remote pulling/pushing arms were at some crazy angles! We also used silastic on the body of the acutators/slave units to stop rattling.
They won't simply bolt in - and they tell you dont do the arms at weird angles. You have no choice really but mines been working well for over 6 months now.
Guest
Post by Guest » Thu Dec 01, 2005 7:13 am
The best way to do it would be to scrounge a wreckers for a set of GL central locking actuators. Very easy to fit, just clips and a few screws.
smoov
Post by smoov » Thu Dec 01, 2005 7:16 am
Touring Wagons also have central locking.
1998 Subaru Legacy GTB
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Dec 01, 2005 10:50 am
I mounted the motors on an aftermarket central locking kit on the diagonal that the hand controls run to the locking mechanism, there is enough room to mount them on all doors there
mattims
Post by mattims » Thu Dec 01, 2005 2:50 pm
i mounted mine in a 92 L series without any griding/cutting. Only needed to drill 2 holes. I will get some pics for you if you want. Had to make some nicely bent bits of rod to actually connect to the lock but that was it.
I did not mount the actuator in line with a rod in the car as suggested by the kit instructions. I mointed it point basically straight up and down and hooked the rod directly onto the locking mechanism (there was a little look that looked like it was made for it). The actuator ended up being quite low in the door (about the level of the base of the window when fully down) and there was enough space in between the inner door frame and the window mechanism.
Let me know if you want some pics and ill pull the door skins off and show you what i did.
Fang
Post by Fang » Thu Dec 01, 2005 6:40 pm
Hmm - there was no way we were going to get the kit I bought in without cuttings ours - Mine was a quality $35 effort.
mattims
Post by mattims » Thu Dec 01, 2005 9:22 pm
mine was only $50 .. from jaycar .. not sure if thats a wa only store or not
Fang
Post by Fang » Thu Dec 01, 2005 9:26 pm
Nah Jaycar is over here too. I guess there are just different sizes etc. I was being sarcastic about the "quality" bit. I think the brand name was something corny like "Steal mate"
Post by Alex » Thu Dec 01, 2005 11:14 pm
ok cheers fellas, sum pics would be very nice, if it aint too much trouble!!
thanks
mattims
Post by mattims » Fri Dec 02, 2005 10:16 am
ill take some pics for you on saturday.
Chris_Rogers
Post by Chris_Rogers » Mon Jan 30, 2006 6:15 pm
smoov wrote:Touring Wagons also have central locking.
and its a HELL of a lot easier to swap them over rather than doing the force it to fit idea. the switch the the drivers door is the only part that goes bad in them
done a few L series sedans that way. get the windows whilst you are at it.
