IS IT POSSIBLE TO RUN THE FULL LIB HARNESS INTO AN L SERIES?
Looking at ej22 for my L,am wondering if the whole harness will fit easily and if it can run all the lights,wiper motor,etc...
I want to use the steering column with all the switches as well as the gauges.
Is that possible?
Is there enough room under the dash for all the wiring/computer?
Not worried about a/c yet.
What about the rear harness? Can the L harness be spliced in the lib??
Thanx
CC
Is that possible?
Thanx
CC
Anything is possible... but DAMN thats a lot of hard work. I wouldn't even attempt to pay someone to do it... could take a very long time. If you can;t do it yourself i wouldn't bother.
Chances are a lot of electrical devices are wired up differently from an L to a lib. For example the wipers would most probly have a different number of wires running to and from the motor and the switch.
Might be easy to buy a lib and wedge L series body pannels on.
Dave
Dave
EJ Wiring
I have done this and it isn't a major drama, time wise no worse than stripping out all the motor loom and splicing it in. It doesn't take up much space and you can put all the dash wiring into the L dash and use the Lib cluster. You will need the whole body loom aswell. As you say you can use all the wiper/light stalks. It is easy to get the fuel guage working and the indicators and brake lights just need the L plugs soldered on. Obviously you get cruise etc aswell. If you want to run the auto I would say this is the best way to do it as it is all there ready to go.
q
Hey legacytt,thanx for your positive input,
i will be doing it myself and i have all the parts to do it so i figured that it must be possible.
I will be running a manual gearbox and no cruise,and it's all going in a std L with no e/w or c/l so all i want is the bare essential and a/c.
Is your a/c working?
What g/box are you running?
I am thinking hi/low lib
Christian
Christian
- BaronVonChickenPants
ej wiring
I am using an auto. The L series central locking works with a minor fiddle. I haven't got the AC going, more due to not having time to match all the piping up.
While it is certainly possible to change the whole harness as Legacytt has done I would suggest that it is by no means the easiest way. It is easier and probably cheaper over all to have the Liberty harness stripped and prepared and then simply wiring it in to the L power supplies. Sunspares charge $300 to have a harness fully stripped, all relays wired in and all the necessary wires labelled and a detailed explanation supplied. You only need minimal wiring skills to get the engine to fire up(no more than getting a stereo to work) and we provide support should you need it when installing the wiring. The harness is tested prior to posting it out also.
There was a thread on the dead forum detailing the L low range into Lib box swap but it'll be long gone now I guess. Short answer is that it is possible and very effective although really not necessary if the car is used for beach work. You don't even need dual range with an EJ22 for the beach because they have mountains of torque compared to an EA82.
IMO constant 4WD is an absolute necessity for en EJ equipped L or MY that is used on the road as well as offroad. The excessive wheelspin will soon lose it's novelty when used day to day especially in the wet.
q
I still think that an untouched,unbutchered full harness conversion is preferable,i also drive a legacy turbo that some d**k has butchered(harness) and its a nightmare to track the intermittent problems,just trying to simplify the whole conversion.
I can guarantee you that it is easier to trace faults on a seperate engine harness than throwing the whole lot in and trying to get the rest of the car to work. I've seen it all and this is the best(only) way to do it.
I have 50 odd subaru cars with engine conversions running around and have done the wiring for dozens of VW, Brumby and LS EJ conversions and never had a failure, this is the best way to do it.
Most people think the same way, it takes a whole lot of worry out of a conversion to have the wiring sorted for you. $300 covers any EJ harness of any age including turbos, twin turbos and all the late stuff with immobilizers. I start an engine on the ground with the harness after it is prepped and do a select monitor check on it to ensure there is no problems. Battery power and Ignition power will start the engine if it has fuel supply.
Me thinks I'm going to have to go for it. This is my loom, half of it is missing:
I'd be lucky if theres more than a dozen wires that actually make it to a connector, then chances are the other side of the connector is butchered as well.
THEN assuming I get that figured out I have this to contend with:
I think it's a lost cause, what do you think?
Al how long does it take to prepare a loom, it's a 2 connector EJ18 ecu going into an 84 MY touring wagon.
Also, congrats on the birth of you son, it's the greatest feeling in the world isn't it
Jordan.
PS: Sorry about the hijack Christian
Jordan.
