anyone have an a/c wiring diagram for a brumby/ea81, there's a fair few relays and i can't sort out the wiring too easily.
cheers
pete
brumby/ea81 a/c wiring diagram
EA81 A/C wiring
Pete,
I've recently fitted A/C to my '89 Brumby and might be able to help. I do have the diagram from the 83 FSM which I can scan in for you, but I have found that wiring for the A/C changes significantly over the years. I assume you have a later model (post 84) with the relay blocks on the drivers side shock tower (the early 82/83 did not have these and is much easier to wire). I found the best way was to compare similar years for wiring, depending on what was available at the wreckers...
Dean.
Dean.
a/c wiring
hi dean
thanks for this, i was beginning to think that everyone had gone home.
yes, i have the later version with all of the relays, it is a bit confusing.
Pete
Pete
