A/C Help
Posted: Sun Jan 07, 2007 12:08 pm
by timmo
As part of my EA82T converesion I also installed A/C from my donor car. Now its all hooked up and going I have found that the A/C is engaged (compressor & elec fan is switched on) as soon as I switch the interior blower fan on even when the A/C switch on the dash is off. Why is this happening? I havnt had it gassed yet.
Timmo
Posted: Mon Jan 08, 2007 9:21 pm
by timmo
I still havnt sorted out this problem despite checking over the wiring..... does anyone have any suggestions? Any help would be appreciated.
Timmo
Posted: Tue Apr 03, 2007 7:12 pm
by 92Brumby
I retro fitted air con into my 92 brumby over the past few weeks I had this exact problem, where the air con clutch would engage even with the fan off, when i turned the fan on the air con would turn off, even with the a/c switch off.
i took it to an auto electrician who put a relay in near the switch, apparently there was power keeping the air con/triggering the system
Pete
Posted: Tue Apr 03, 2007 9:31 pm
by timmo
yeah to fix my problem I just installed a switch in the wire from the interior fan that triggers the air con. It works. I did notice in my haynes manual that there is a difference in the wiring for the air con between manual and auto trans, and since my air con system came out of an auto i'm suspicious that this may have been what was causing the problem. I dont know what the auto would have different? maybe air con switches off when the downishift switch is triggered at full throttle....? i dont know ...and dont want to know!! haha
timmo
