Page 1 of 2
Flasher unit location + photo (L-series)
Posted: Fri Dec 29, 2006 2:02 am
by SuBaRiNo
Can i bother one of u fine gentlemen for a location and photo of a L series indicator flasher unit.
I realise this is an easy thing to find when the unit is working (search for the clicking unit) but when they are not then it is a bit of a treasure hunt.
I have no idea what this unit is meant to look like... hence needing a photo.
Thanks in advance
Dave
Posted: Fri Dec 29, 2006 8:15 am
by Xtreme_RX
What the indicator flasher?
Its actually part of the indicator stick assembly on the steering hub....
Posted: Fri Dec 29, 2006 9:16 am
by waggaclint
its up under the dash on the right side just next to steering coloum its hard to get apic of it ill have a look l8ter...
Posted: Fri Dec 29, 2006 10:25 am
by SuBaRiNo
Yeah indcator flasher sorry. It's starting to sound like there is a different style flasher unit depending on the year L series....
If it is built into the indicator stick assembly then would that mean u have to replace that entire assembly to change the flasher??
Dave
Posted: Fri Dec 29, 2006 11:36 am
by waggaclint
nah i wouldnt think it would built in mines seperate hey right up under the dash....(like just behind the mirror switch sort of)...ive never seen one one built in on any car hey...
you should see 3 relays like these up behind the fuse block the flasher can (or relay) sits on top of these my flasher can has mitsubi writen on it and its black and square shape it has a screw holding it in place...looks a bit of prick to get out..
Posted: Fri Dec 29, 2006 12:17 pm
by Xtreme_RX
The early models of 'L' Series (single stalk) Models have flasher inbuilt in to the indicator stalk.
Posted: Fri Dec 29, 2006 7:49 pm
by SuBaRiNo
Thanks heaps clint.... So if it is the one built into the stalk then the wntire stalk would have to be replaced right??
Dave
Posted: Sat Dec 30, 2006 10:47 am
by waggaclint
it sound like it hey.....
Posted: Tue Jan 02, 2007 10:59 am
by BlackMale
Now to make it even MORE complex… The pic attached (Thanks waggaclint) is the 3rd different indicator flasher unit I have seen for an L series in the last week. The RX has only 1 of those cylinder units, the touring wagon has a double unit (they are connected) and this pic has 3.
And we say that Subaru’s are easy to work on LOL
(PS thats for getting this up for me Dave).
Posted: Tue Jan 02, 2007 6:44 pm
by SuBaRiNo
Clint said it's on top of them canisters (relays) they are not the actual flasher unit.
Dave
Posted: Tue Jan 02, 2007 7:54 pm
by waggaclint
yeah thats right dave it sits ontop or above those relays its (black and square shaped) if thats any help boys...
Posted: Wed Jan 03, 2007 9:52 am
by BlackMale
So are you saying that its the relay that needs replacing not the actual small cylinders (as pictured)?
Posted: Wed Jan 03, 2007 10:28 pm
by waggaclint
yep thats right it sits just above (the small silver cylinders.......) black in colour...the one in my car has MITSUBI written on it in white writing if that helps...
Posted: Thu Jan 04, 2007 9:49 am
by BlackMale
Nope no help
The flasher unit in the wagon was berried up under the dash and it was a struggle just to get it out. I fear going higher will cause me much frustration and possible nose bleeding n dizzy spells.
Thanks I may pull it apart again on the wkd.
Posted: Thu Jan 04, 2007 11:34 pm
by subanator
Good those L Series dash's hey, after remember getting stuck into that one of that wreck at your place.......LOL
Still yet to do mine, something to to with post-traumatic stress or something????????
Posted: Wed Feb 20, 2013 8:51 pm
by Dann
just bringing up a past thread here with the flasher unit mine recently went when escorting a mate being towed at night, my hazard lights and indicators arent working so i'm guessing this should be the problem??? does the unit look like this... pic
Posted: Thu Feb 21, 2013 12:11 am
by RSR 555
Dann wrote:just bringing up a past thread here with the flasher unit mine recently went when escorting a mate being towed at night, my hazard lights and indicators arent working so i'm guessing this should be the problem??? does the unit look like this... pic
Nope. This is either the A/C Rev counter or the Wiper Control Unit
The Flasher Unit should be a round silver looking unit
Posted: Thu Feb 21, 2013 7:13 am
Not the wiper control unit, they have been grey boxes so far - that unit is something like the stop the electric fuel pump in case of an accident - about 350 bucks for a new one.
Dann, can you tel us year model or make date of your L, maybe even a pic of the indicators at the column. Er, you have checked fuses ?
Posted: Thu Feb 21, 2013 6:25 pm
by Dann
yeah it's a 1992 l series standard one built- Jan 1992 on a Wednesday... haha jokes but the Jan 1992 part is right, and yes I've checked all fuses, can somone post a photo of the exact relay of the flasher unit,cause i thought it would be the silver canasters too but this thread says otherwise, anyway I put the car in test mode and one at a time swapped all the relays around( only the same type ones) with one that was working and all of them worked, unless the unit is tucked right up under the dash?
Posted: Thu Feb 21, 2013 7:26 pm
by tambox
Hark ye all, when all faith is lost, read the 1990 bible:D
A 3 wire plug on the LHS of the steering column.
