Engine management - Wolf3D
Posted: Wed Dec 27, 2006 12:58 pm
by BlackMale
Not sure if i should be here or the mods and performance section... it's all wires to me.
Tis a long short but I’ll give it a crack.
Just seeing what the chances would be of getting my hands on a second hand Wolf 3D engine management system for an EA82T?
At this stage its an interest thing and it is possible that $ will be the killer of this idea however I am willing to explore it and/or listen to others suggestions/ideas.
Thanks
Posted: Wed Dec 27, 2006 1:26 pm
by BrennyV
microtec
Posted: Wed Dec 27, 2006 2:56 pm
by mattims
i've used one before and never had any problems with it. Manuals etc were fine and the software was nothing flash but it did the job. It always felt like a cheap unit with the look of the hand controller but other than that it was ok.
only slight problem i had with it was that it that it had a Surface Mount Fuse inside the case that was an absolute prick to replace and i did blow it twice (although it was fair enough it blew because the ignition module was dodgy at the time it blew).
Posted: Wed Dec 27, 2006 10:21 pm
by waggaclint
go with 4muff get a microtec there heaps better....i used to work at a dyno place and we used to have alot of problem getting the wolf set up properly hey but the microtec was great hey....just remember either way you will need to set it up on dyno to get right you will neva get it spot on tuning on the road hey...that my opinion anyway ive fitted both and i reckon the microtec is better....
Posted: Wed Dec 27, 2006 10:50 pm
by BrennyV
werd to muh homie clint!
Posted: Wed Dec 27, 2006 11:37 pm
by waggaclint
what the ?
Posted: Thu Dec 28, 2006 1:03 am
by tim_81coupe
Are you feeling OK Brendan? For a moment there you sounded like Chingy.
Werd. Pfft.
Posted: Thu Dec 28, 2006 8:21 am
by BrennyV
hahaha dno, wanted to sound 'hardcore'
Posted: Thu Dec 28, 2006 10:59 am
by Oversteer
New new offerings from either are pretty good....just don`t buy an old V3 Wolf3D or earlier than current release Microtech. The early units were raw and nasty.
OS
Posted: Sat Dec 30, 2006 10:05 pm
by schultzie
i like my wolf... and the new hand controllers are compatable with the older units...
if you go wolf i will send you a copy of my tune... so at least you can get it running,
i like the wolf the car starts every time... but ill let you know more after i get it tuned in the next few months...
Posted: Sun Dec 31, 2006 7:01 pm
by steve_rising_sun
I have fitted 6 or so wolfs I think they are great
Steve
Posted: Tue Jun 16, 2009 10:06 pm
by phillatdarwin
do u still run a wolf3d and can u send me some setting so i do not have to play around so much to tune it as i do not like a dyno as a dyno is not teh same as driveing it on the road
