Engine management - Wolf3D
Not sure if i should be here or the mods and performance section... it's all wires to me.
Tis a long short but I’ll give it a crack.
Just seeing what the chances would be of getting my hands on a second hand Wolf 3D engine management system for an EA82T?
At this stage its an interest thing and it is possible that $ will be the killer of this idea however I am willing to explore it and/or listen to others suggestions/ideas.
Thanks
Thanks
microtec
Hunter S. Thompson
Hunter S. Thompson
i've used one before and never had any problems with it. Manuals etc were fine and the software was nothing flash but it did the job. It always felt like a cheap unit with the look of the hand controller but other than that it was ok.
only slight problem i had with it was that it that it had a Surface Mount Fuse inside the case that was an absolute prick to replace and i did blow it twice (although it was fair enough it blew because the ignition module was dodgy at the time it blew).
- waggaclint
go with 4muff get a microtec there heaps better....i used to work at a dyno place and we used to have alot of problem getting the wolf set up properly hey but the microtec was great hey....just remember either way you will need to set it up on dyno to get right you will neva get it spot on tuning on the road hey...that my opinion anyway ive fitted both and i reckon the microtec is better....
2011 Forester X
werd to muh homie clint!
Hunter S. Thompson
Hunter S. Thompson
- waggaclint
- tim_81coupe
hahaha dno, wanted to sound 'hardcore'
Hunter S. Thompson
Hunter S. Thompson
New new offerings from either are pretty good....just don`t buy an old V3 Wolf3D or earlier than current release Microtech. The early units were raw and nasty.
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
- steve_rising_sun
- phillatdarwin
