altering 98 wrx wiring harness
gx_rex
Post by gx_rex » Wed Dec 20, 2006 9:02 pm
i am soon putting a 98 wrx running gear into my 96 impreza.
i have just managed to source the wiring harness to suit the 98 wrx engine and hope to get the engine running by end of week as soon as i get the ecu.
i figure that using this harness the engine will run as per standard so all i should need to do is alter the part that plugs into the instrument cluster, air con and heater controls.
anyone know where i can get the wiring diagrams for both 96 and 98 wrx instrument clusters so i can make a custom adapter harness?
Brumby Boy
Post by Brumby Boy » Wed Dec 20, 2006 10:12 pm
I can photo copy them out of the manuals at work and fax them to you if you want.
RIP 1992 Brumby
gx_rex
Post by gx_rex » Thu Dec 21, 2006 6:59 am
i dont have a fax but if you can scan them onto computer and email them to corriecds@hotmail.com would be great...
vincentvega
Post by vincentvega » Thu Dec 21, 2006 8:10 am
why arent you installing the complete 98 loom / dash etc? Would make for a far more complete, reliable solution
gx_rex
Post by gx_rex » Thu Dec 21, 2006 8:30 am
i am installing the entire loom but i dont have the dash. if i did have the dash i would have to change door trims etc as well...
had i got a front cut i agree that would have been the easy way...
Post by AndrewT » Thu Dec 21, 2006 9:16 am
It may be easier to cut the WRX loom down to the bare essentials required to run the engine and leave the car's loom alone. Just a thought.
gx_rex
Post by gx_rex » Thu Dec 21, 2006 10:05 am
well the gx is only 2wd and i am upgrading it to full 98 wrx running gear including abs etc...
using the 98 wrx loom i get to retain the abs etc so i just need to wire up the instrument gauges and stuff and other than that it will be all as if it was standard 98 wrx...
seagull
Post by seagull » Thu Dec 21, 2006 12:49 pm
swap the 98 for a 94 with abs ???
seagull
gx_rex
Post by gx_rex » Thu Dec 21, 2006 9:37 pm
seagull wrote:swap the 98 for a 94 with abs ???
seagull
swap what the harness??
wont run my engine then....
Brumby Boy
Post by Brumby Boy » Thu Dec 28, 2006 7:14 pm
i dont have a scanner sorry
RIP 1992 Brumby
