Joining sheilded wires
- stamp_licker
Anyone know to connect sheilded wires together?i have a bit of sheilded wire with 3 wires going to a g/box plug that,s not long enough to reach the tcu,at the other end i have a tcu plug with a long lenght of sheild wire with 3 wires also at the plug but where it is cut in the middle there are only 2 wires and a bit of sheilding.I'm thinking that one of the 3 wires is joined into the sheilding at each plug end.
Building a hardcore postie:D
As a general principle, all you need to do is to join the individual internal wires, insulate them and connect the two shields together. In an automotive application it very likely wouldn't matter if you didn't wrap up the zone with the joins in shielding.Anyone know to connect sheilded wires together?
Possibly. You'll be able to tell using your multimeter.I'm thinking that one of the 3 wires is joined into the sheilding at each plug end.
- vincentvega
- Suby Wan Kenobi
- stamp_licker
- Suby Wan Kenobi
- stamp_licker
