Tacho
robdddd
Tacho
Post by robdddd » Wed Nov 15, 2006 3:32 pm
Recently put an EJ22 in my L series.....there is a wire from the computer that is fo a Tacho, will this be suitable to run any off the shelf tacho? I assume it is just sending some sort of pulse signal ?
stinky
Post by stinky » Wed Nov 15, 2006 4:06 pm
yeah it should be. the one off my EJ18 works fine with the indash tacho on my '81 sedan.
Post by Subafury » Wed Nov 15, 2006 7:29 pm
either that or connect it to the negative side of the ignition coil.
SuBaRiNo
Post by SuBaRiNo » Wed Nov 15, 2006 9:34 pm
Subi that wont work with an EJ22.
And yes that wire on the ECU will run any tacho... factory or aftermarket... there was some debate before to what the signal outputs but i have run mine off the factory one in the dash and an aftermarket one.
It is a negative pulse just like the negative side of the coil puts out.
Dave
SuBaRiNo
Post by SuBaRiNo » Wed Nov 15, 2006 9:35 pm
I can help with the ECU pinout for the tacho wiring if u need it too.
Dave
tim_81coupe
Post by tim_81coupe » Wed Nov 15, 2006 10:53 pm
Black Blue on a 4 plug ECU.... can't remember which plug exactly but the wire is black/blue.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
SuBaRiNo
Post by SuBaRiNo » Wed Nov 15, 2006 11:26 pm
ECU pinouts.
Dave
robdddd
Post by robdddd » Thu Nov 16, 2006 3:10 pm
Thanks guys..........now I can get a tacho
