old thermo fan
old thermo fan
Post by Subafury » Sat Nov 04, 2006 5:36 pm
the bearing in my thermo fan is buggered (solved my strange noise problem) and was wondering if an aftermaket fan would give better cooling ie spin faster, than the ol' L series one?
otherwise ill just replace the fan.
SuBaRiNo
Post by SuBaRiNo » Sat Nov 04, 2006 6:55 pm
Im sure the aftermarket ones would be better if you can make em fit.
Dave
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Nov 04, 2006 9:20 pm
If you are handy you can adapt a liberty fan to fit in there with minimal fuss and they work about 200% better than the old L ones
The long road ahead
SuBaRiNo
Post by SuBaRiNo » Sun Nov 05, 2006 1:05 am
How good are they compared to aftermarket ones though?? could be a lot of fuss for little gain. Also with aftermarket ones u have a choice of sizes and different mounting options.
Dave
Post by Subafury » Sun Nov 05, 2006 7:59 pm
i just priced up a davies craig one. computa says: $140 part no: 0045 or something.
for anyone (AndrewT?) thats bought one before, does this sound resonable?
subanator
Post by subanator » Mon Nov 06, 2006 12:01 am
A street mag I read recently said via testing aftermarket etc for efficiency etc reckon that the Ford Modeo or similar Falcon fans used with shrouds work best, dont know what they go for at the wreckers etc?
The photos showed 2x fans mounted diag across the rad in the shroud.
Post by Subafury » Mon Nov 06, 2006 10:38 pm
i was randomly workin at morley supercheap today and coincidently the correct fan for my L (as above)fan was sittin on the shelf like a clearance item. i snapped it up for super cheap!!!
Suby Wan Kenobi
Post by Suby Wan Kenobi » Mon Nov 06, 2006 10:52 pm
I have a heap of Liberty fans lying around so it was the "cheapest" option for me
The long road ahead
Post by Subafury » Tue Nov 07, 2006 9:12 pm
put it in today. was the easiest fit id done. i sorta wedged it into the existing shroud as the new fan and its surrounding just fit inside. then just bolted it back up and wired it. easy. havent been for a test run yet but it spins a hell of a lot faster than the old one.
