On my MY Sedan when I did the EJ conversion I had two positives going to the alternator, an 'always on' and an 'ignition'. I hooked them up to the EJ alternator in what I thought was the right order, but I think I got them backwards as it would drain the battery over time and if I put my head right up to it there was a slight whine coming from it even when engine was off.
The EJ Alternator has two connections for +ve power, should I have ig in one, and constant in the other ? If so I'm guessing I just swap over what I've got as I probably got them wrong. Otherwise maybe I should unhook the constant all together ?
EJ Alternator wiring
There are a few different EJ alternators but from your description it sounds like you have a gen 2 type. The large white wire is the sensing wire, it just goes to the battery(just connect it straight to the post on the alternator). The other wire(black/white) is the charge light wire. There is no ignition sw wire on these alternators. The charge light must be working for the alternator to charge correctly. The black/white wire on the MY will be ignition power so don't just assume that the colours will match.
If you have a lot of high current electrical equipment you should run some new wires from the alternator post to the battery via a fusible link as the orignal wiring is not large enough for the alternators output. This is only usually and issue if you have large spotlights or run fridges etc.
Cheer. Al.
Early alternators have a 4 pin round plug, they require sensing wire, light and an ignition feed to charge, the 4th wire is for Jap cars for some kind of ecu control.
2 Plug ecus are much more reliable and charge higher at idle. It is a simple job to replace an early alt with a 2 pin gen 2 alt(bolt on and minor wiring change) This is a good upgrade.
Cheer. Al.
