Stop Lamp Warning Lamp Control Unit
Posted: Sat Sep 30, 2006 3:59 pm
by maddog
Hi All - Does anyone know where the Stop Lamp Warning Lamp Control Unit lives?
(L Series Wagon 1987) The warning light comes on whenever you brake but both brake lights are working...??? My wiring diagram shows a S.L.W.L.C.U. but I have no idea where it is - and i reckon it's faulty! Any clues anyone?
Thanks in anticipation...
Posted: Sun Oct 01, 2006 8:53 am
by Matt
It will more then like be in the dash off memory....
Posted: Sun Oct 01, 2006 10:52 am
by maddog
Thanks Matt - at least that narrows it down to somewhere in the spaghetti under the dash!
Posted: Sun Oct 01, 2006 11:02 am
by Lapsed
check your brake fluid levels, mine did this and it was very low
Posted: Sun Oct 01, 2006 12:24 pm
by SuBaRiNo
I heard this is a comon problem when the wrong globes are fitted in the tail lights mixed with the resistance of the old cabling in the car.
I can't say where an L series one is.... but in an MY wagon its in the (drivers side i think) rear quarter panel and on the MY sedans it's built into the (passanger side i think) tail light assembly.
I think Tim knows more about this.
Dave
Posted: Mon Oct 02, 2006 5:28 pm
by Gannon
There is a small circuit board mounted on the back of the drivers side rear light. im only guessing that it might be this.
Medal of Honour for Suparoo
Posted: Thu Oct 05, 2006 6:16 pm
by maddog
Suparoo - You get the award for the most accurate information!!!!
You were 100% correct - board is attached to rear drivers light assembly. The only bugger is that you need to swap the wiring loom for the rear light assembly, the board is soldered in and I didn't want to risk wrecking the good unit!
Thank you Subaru Guru!!!
Posted: Fri Oct 06, 2006 4:07 am
by Matt
My appoligies Maddog, what i ment by in dash, was in the instrument cluster part, which was wrong anyway.
Posted: Fri Oct 06, 2006 9:19 am
by AndrewT
I don't think it would be the brake fluid....there is a separate warning light for that. Unless it's different in Touring wagons..?
My Tourer (and my old one) has a warning light for blown brake lights and another one for low fluid.
Sounds like Subarino is on the ball there - try changing the rear globes for a different brand or wattage.
Posted: Fri Oct 06, 2006 11:33 am
and in Brumbys, there is some thing with a zillion wires mounted inside the cabin centrally behind the covers midway between back window and floor, from memory, i think this controls most dash warning lights
Posted: Fri Oct 13, 2006 9:45 pm
by maddog
(Brake fluid level was at max)
I tried changing the globes first - easiest option - but this didn't make any difference. I swapped complete rear light wiring loom and this fixed it.
I then retested the original wiring loom and the fault reappeared.
I'd say it was the circuit board. QED.
Thanks to all for your input - it was fun!
